0005521 | ParaView | (No Category) | public | 2007-08-16 15:36 | 2011-01-13 17:00 | ||||
Summary | 0005521: Add a ruler source/filter | ||||||||
Description | A user has requested that we add a ruler type feature to ParaView. This user wants to know how far two cells, points, or objects are from each other. | ||||||||
(0008494) Alan Scott (manager) 2007-08-16 19:00 |
In ParaView 2.6, you do this with the icon that looks like a ruler. It is a line source. You place the ends of the line on a surface by hitting the 'p' key. The length is displayed right below the x,y, and z of point 1 and point 2 (on the Parameters tab). PV 3.0 has a line source, but 1) you cannot place the ends easily on the top of a surface, and 2) it does not display the length of the line. |
(0010548) Alan Scott (manager) 2008-02-18 15:18 |
I am changing this to High priority. We have had multiple requests that we have some type of ruler function. We need to at least implement either this feature, or 5422. |
(0011947) Utkarsh Ayachit (administrator) 2008-05-15 13:57 |
Change line source to show length information somewhere. |
(0011974) Utkarsh Ayachit (administrator) 2008-05-16 15:56 |
A new "Ruler" source has been added. |
(0012060) Alan Scott (manager) 2008-05-21 22:50 |
I'm pretty sure this is messing up the cube axis. Thus, asking for feedback on this bug. Please run exactly as follows: * Client/server - 6 servers. XP client. * Open disk_out_ref.exo. Apply. * Sources/ Ruler. (Don't hit apply) * On bottom of cylinder, hit a 'p'. * On top of cylinder, hit a 'p'. (Note, it would sure be nice to document somehow that you could hit a p here.) (Note, it would sure be nice to auto-accept here.) * Apply. * Display tab/ Show cube axes. The axes are located inside of the cylinder. |
(0012061) Alan Scott (manager) 2008-05-21 22:54 |
Ah-hah. Lots of the junk above doesn't have to be done - the cube axes for the ruler is always weird. Turns out that it is putting the cube axes around the ruler itself. Does this make sense - should we just leave it, or should we turn off the Show Cube Axes for the ruler (and does that make sense)? |
(0012068) Utkarsh Ayachit (administrator) 2008-05-22 07:42 |
Berk was suggesting we don't create any representation for the ruler. In otherwords, the display tab will never be enabled for the ruler, hence one will never see the cube-axes. Does that work? I am guessing, however, the cube-axes has issues dealing with 1D data. So that is a bug we'd surely want to fix at some point. |
(0012167) Utkarsh Ayachit (administrator) 2008-05-30 14:55 |
We can no longer apply cube-axes to the ruler. |
(0012192) Alan Scott (manager) 2008-06-02 18:58 |
Very nice. Now, when we turn on the ruler, and hit Apply (the button goes green), a seperate window opens up - with only the ruler in it. XP client/ 6 pvservers Open can.exo, apply. Sources/ Ruler/ apply. |
(0012193) Alan Scott (manager) 2008-06-02 18:59 |
Oh yes - when you close the separate window, PV crashes. |
(0012271) Utkarsh Ayachit (administrator) 2008-06-06 09:42 |
* vtkLineRepresentation was not passing the renderer to the internal representations, consequently, when the view was destroyed the internal representations had a dangling pointer which led to segfaults. * pqDisplayPolicy was create a new render view even when the render view could not show the current source. This was resulting the a new 3D view being created when a ruler source was created. Fixed that. /cvsroot/ParaView3/ParaView3/Qt/Core/pqDisplayPolicy.cxx,v <-- Qt/Core/pqDisplayPolicy.cxx new revision: 1.38; previous revision: 1.37 /cvsroot/ParaView3/ParaView3/VTK/Widgets/vtkLineRepresentation.cxx,v <-- VTK/Widgets/vtkLineRepresentation.cxx new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/VTK/Widgets/vtkLineRepresentation.h,v <-- VTK/Widgets/vtkLineRepresentation.h new revision: 1.6; previous revision: 1.5 |
(0012296) Alan Scott (manager) 2008-06-09 20:51 |
Great new feature. Tested local client. Blackrose is down. |
2007-08-16 15:36 | Alan Scott | New Issue | |
2007-08-16 19:00 | Alan Scott | Note Added: 0008494 | |
2007-08-29 16:00 | Berk Geveci | Status | backlog => tabled |
2008-02-18 15:18 | Alan Scott | Note Added: 0010548 | |
2008-02-18 15:18 | Alan Scott | Priority | normal => high |
2008-02-18 15:18 | Alan Scott | Category | => 3.2 |
2008-04-14 17:10 | Berk Geveci | Assigned To | => Berk Geveci |
2008-04-14 17:10 | Berk Geveci | Category | => 3.4 |
2008-05-15 13:57 | Utkarsh Ayachit | Note Added: 0011947 | |
2008-05-15 13:57 | Utkarsh Ayachit | Assigned To | Berk Geveci => Utkarsh Ayachit |
2008-05-16 15:56 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-05-16 15:56 | Utkarsh Ayachit | Resolution | open => fixed |
2008-05-16 15:56 | Utkarsh Ayachit | Note Added: 0011974 | |
2008-05-21 22:50 | Alan Scott | Status | @80@ => @20@ |
2008-05-21 22:50 | Alan Scott | Resolution | fixed => reopened |
2008-05-21 22:50 | Alan Scott | Note Added: 0012060 | |
2008-05-21 22:54 | Alan Scott | Note Added: 0012061 | |
2008-05-22 07:42 | Utkarsh Ayachit | Note Added: 0012068 | |
2008-05-30 14:55 | Utkarsh Ayachit | Status | @20@ => @80@ |
2008-05-30 14:55 | Utkarsh Ayachit | Resolution | reopened => fixed |
2008-05-30 14:55 | Utkarsh Ayachit | Note Added: 0012167 | |
2008-06-02 18:58 | Alan Scott | Status | @80@ => @20@ |
2008-06-02 18:58 | Alan Scott | Resolution | fixed => reopened |
2008-06-02 18:58 | Alan Scott | Note Added: 0012192 | |
2008-06-02 18:59 | Alan Scott | Note Added: 0012193 | |
2008-06-06 09:42 | Utkarsh Ayachit | Status | @20@ => @80@ |
2008-06-06 09:42 | Utkarsh Ayachit | Resolution | reopened => fixed |
2008-06-06 09:42 | Utkarsh Ayachit | Note Added: 0012271 | |
2008-06-09 20:51 | Alan Scott | Status | @80@ => closed |
2008-06-09 20:51 | Alan Scott | Note Added: 0012296 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
