0005502 | ParaView | (No Category) | public | 2007-08-15 15:36 | 2016-08-12 09:57 | ||||
Priority | normal | Severity | feature | Reproducibility | N/A | ||||
Target Version | Someday | Fixed in Version | |||||||
Summary | 0005502: Fix representations to not dependend of order of setting input and adding to view | ||||||||
Description | Currently representations require that the input is set before adding the representation to the view. Also the representation objects are not created until the input is set. This restriction can be easily lifted by setting up the pipeline and strategies only after the representation has been added to a view and has an input, without any restrictions on when the objects are actually created. | ||||||||
(0037526) Kitware Robot (administrator) 2016-08-12 09:57 |
2007-08-15 15:36 | Utkarsh Ayachit | New Issue | |
2007-08-15 15:36 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2007-08-15 15:36 | Utkarsh Ayachit | Status | backlog => tabled |
2008-04-14 17:04 | Berk Geveci | Category | => Someday |
2009-05-13 13:49 | Utkarsh Ayachit | Target Version | => Someday |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037526 | |
