0005461 | ParaView | (No Category) | public | 2007-08-08 15:08 | 2009-05-13 13:59 | ||||
Reporter | John Greenfield | ||||||||
Summary | 0005461: Exodus Reader needs to handle restart files | ||||||||
Description | This could either be an animatiuon or an exodus reader issue. Need to be able to read exodus files with sequential or overlapping timesteps and animate them as a single sequence. The common case here is restart files --typically if a simulation crashes and has to be restarted we wind up with a sequence of files named test.e, test.e-s0002, test.e-s0003 ... Each file will contain one or more timesteps (in some cases overlapping -- typically each subsequent file repeats the last timestep or two from the previous one with the later files timesteps being the correct ones). We need a way to open a all of these files (even if each one is split geometrically as well) and animate all of them sequentially over time. | ||||||||
Relationships | ||||||
(0011300) Ken Moreland (manager) 2008-04-14 17:47 |
Can you acquire (or generate) a simple file set that we can use for testing? It will have to be something small and that can be R&A'ed as UUR so that we may place it in the testing data repository. |
(0011691) Ken Moreland (manager) 2008-05-05 08:54 |
Added a new "restarted exodus" reader. It reads in a file with an extension named .ex-timeseries. This file is just a simple text file with a list of all the files (or the first file in a series). I currently do not have a test for the reader because I do not have an appropriate data file yet. I'm going to change the owner to Alan to procure a data set. After he does that, I'll add a test. /cvsroot/ParaView3/ParaView3/Qt/Components/pqObjectInspectorWidget.cxx,v <-- Qt/Components/pqObjectInspectorWidget.cxx new revision: 1.67; previous revision: 1.66 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/XML/ParaViewReaders.xml,v <-- Qt/Components/Resources/XML/ParaViewReaders.xml new revision: 1.22; previous revision: 1.21 /cvsroot/ParaView3/ParaView3/Servers/Filters/CMakeLists.txt,v <-- Servers/Filters/CMakeLists.txt new revision: 1.167; previous revision: 1.166 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkExodusFileSeriesReader.cxx,v <-- Servers/Filters/vtkExodusFileSeriesReader.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkExodusFileSeriesReader.h,v <-- Servers/Filters/vtkExodusFileSeriesReader.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkFileSeriesReader.cxx,v <-- Servers/Filters/vtkFileSeriesReader.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkFileSeriesReader.h,v <-- Servers/Filters/vtkFileSeriesReader.h new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/readers.xml,v <-- Servers/ServerManager/Resources/readers.xml new revision: 1.126; previous revision: 1.125 |
(0011876) Alan Scott (manager) 2008-05-13 17:36 |
Here it is back again. I sent you files that should work for testing, that are publicly releasable. Enough documentation to allow testing (at least) would be appreciated. |
(0012005) Ken Moreland (manager) 2008-05-19 14:47 |
Added a pqClientExTimeseries regression test. Documentation on using the Exodus timeseries reader is now on the ParaView wiki: http://www.paraview.org/Wiki/Restarted_Simulation_Readers#Exodus [^] |
(0012074) Alan Scott (manager) 2008-05-22 20:52 |
YESSSSS! This is fabulous. Tested client/server. |
2007-08-08 15:08 | John Greenfield | New Issue | |
2007-08-29 15:48 | Berk Geveci | Assigned To | => Ken Moreland |
2007-08-29 15:48 | Berk Geveci | Status | backlog => tabled |
2007-08-29 15:48 | Berk Geveci | Category | => 3.2 |
2008-04-14 16:56 | Berk Geveci | Category | => 3.4 |
2008-04-14 17:47 | Ken Moreland | Note Added: 0011300 | |
2008-04-14 18:12 | Ken Moreland | Relationship added | related to 0006063 |
2008-05-05 08:54 | Ken Moreland | Note Added: 0011691 | |
2008-05-05 08:57 | Ken Moreland | Assigned To | Ken Moreland => Alan Scott |
2008-05-13 17:36 | Alan Scott | Note Added: 0011876 | |
2008-05-13 17:36 | Alan Scott | Assigned To | Alan Scott => Ken Moreland |
2008-05-13 17:36 | Alan Scott | Status | tabled => @20@ |
2008-05-19 14:47 | Ken Moreland | Status | @20@ => @80@ |
2008-05-19 14:47 | Ken Moreland | Resolution | open => fixed |
2008-05-19 14:47 | Ken Moreland | Note Added: 0012005 | |
2008-05-22 20:51 | Alan Scott | Status | @80@ => closed |
2008-05-22 20:52 | Alan Scott | Note Added: 0012074 | |
