0005441 | ParaView | (No Category) | public | 2007-08-01 13:10 | 2009-05-13 13:59 | ||||
Reporter | Clinton Stimpson | ||||||||
Summary | 0005441: undo/redo with animation doesn't work right | ||||||||
Description | (*) means undo step created * create a sphere * add a keyframe for center(0) go to index 1 *add another keyframe go back to index 1 * change time to 0.5 * change value to 1 Hit undo and instead of changing the value back to 0, it removed a keyframe. hit undo again, and it removes all keyframes. hitting redo twice doesn't give you back the same stuff. Also, shutting down at this point gives a segfault. compare: * create a sphere * add a keyframe for center(0) *add another keyframe * change value to 1 hit undo and value goes from 1 to 0. hit undo and middle keyframe is removed hit undo and all keyframes are removed that works as expected I get the same problem whether I do the above with the new animation GUI. | ||||||||
(0011291) Berk Geveci (administrator) 2008-04-14 16:55 |
Fix it in 3.4 if relatively easy. 3.6 otherwise. |
(0011871) Utkarsh Ayachit (administrator) 2008-05-13 14:27 |
Wasn't able to reproduce. If I am following the steps correctly, undo/redo seems to works fine for the case indicated. |
(0011911) Alan Scott (manager) 2008-05-14 15:15 |
Could you verify that this is fixed, or please clarify the directions. I get lost at "go to index 1". Thanks |
(0011915) Clinton Stimpson (developer) 2008-05-14 15:21 |
It has been fixed. "go to index 1" means to change the keyframe index to 1. And these steps are with the animation inspector, not the newer animation view. |
(0011917) Alan Scott (manager) 2008-05-14 15:30 |
Reporter says fixed. Thus, closed. |
2007-08-29 15:37 | Berk Geveci | Assigned To | Berk Geveci => Utkarsh Ayachit |
2008-04-14 16:55 | Berk Geveci | Note Added: 0011291 | |
2008-04-14 16:55 | Berk Geveci | Category | => 3.4 |
2008-05-13 14:27 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-05-13 14:27 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2008-05-13 14:27 | Utkarsh Ayachit | Note Added: 0011871 | |
2008-05-14 15:15 | Alan Scott | Assigned To | Utkarsh Ayachit => Clinton Stimpson |
2008-05-14 15:15 | Alan Scott | Status | @80@ => @20@ |
2008-05-14 15:15 | Alan Scott | Resolution | unable to reproduce => reopened |
2008-05-14 15:15 | Alan Scott | Note Added: 0011911 | |
2008-05-14 15:21 | Clinton Stimpson | Status | @20@ => @80@ |
2008-05-14 15:21 | Clinton Stimpson | Resolution | reopened => fixed |
2008-05-14 15:21 | Clinton Stimpson | Note Added: 0011915 | |
2008-05-14 15:30 | Alan Scott | Status | @80@ => closed |
2008-05-14 15:30 | Alan Scott | Note Added: 0011917 | |
