0005421ParaView(No Category)public2007-07-27 11:192007-08-23 09:13
ReporterKen Moreland
Assigned ToUtkarsh Ayachit
PriorityhighSeveritymajorReproducibilityalways
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Summary0005421: Disconnect server animation not working with exodus files
DescriptionIn client/server mode, load the can.ex2 dataset. Adjust the camera so that you can see the can crush and then save the animation with the disconnect and save option enabled. When the animation is written out, it will have the same image in every frame.
TagsNo tags attached.
Project
Topic Name
Type
-  Notes
(0008536)
2007-08-21 09:19
The links between views and time keeper were not registered with proxy manager. As a result, when the state was loaded on the server side, playing the animation (which changes the time on time keeper) never affected the views. Simply registering these links would make it difficult to avoid duplicate links when state is loaded. Instead added a "Views" property to the timekeeper which setups up the view links.
(0008537)
2007-08-21 09:20
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/CMakeLists.txt,v <-- CMakeLists.txt
new revision: 1.196; previous revision: 1.195
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMServerProxyManagerReviver.cxx,v <-- vtkSMServerProxyManagerReviver.cxx
new revision: 1.8; previous revision: 1.7
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMTimeKeeperProxy.cxx,v <-- vtkSMTimeKeeperProxy.cxx
initial revision: 1.1
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMTimeKeeperProxy.h,v <-- vtkSMTimeKeeperProxy.h
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/utilities.xml,v <-- utilities.xml
new revision: 1.130; previous revision: 1.129
/cvsroot/ParaView3/ParaView3/Qt/Components/pqStateLoader.cxx,v <-- pqStateLoader.cxx
new revision: 1.12; previous revision: 1.11
/cvsroot/ParaView3/ParaView3/Qt/Components/pqUndoStackBuilder.cxx,v <-- pqUndoStackBuilder.cxx
new revision: 1.5; previous revision: 1.4
/cvsroot/ParaView3/ParaView3/Qt/Core/pqTimeKeeper.cxx,v <-- pqTimeKeeper.cxx
/cvsroot/ParaView3/ParaView3/Qt/Core/pqTimeKeeper.h,v <-- pqTimeKeeper.h
/cvsroot/ParaView3/ParaView3/Qt/Core/pqView.cxx,v <-- pqView.cxx
- Issue History
2007-08-13 15:02 Berk Geveci Assigned To Berk Geveci => Utkarsh Ayachit
2007-08-21 09:19 Utkarsh Ayachit Status tabled => @80@
2007-08-21 09:19 Utkarsh Ayachit Resolution open => fixed
2007-08-21 09:19 Utkarsh Ayachit Note Added: 0008536
2007-08-21 09:20 Utkarsh Ayachit Note Added: 0008537
2007-08-23 09:13 Ken Moreland Status @80@ => closed
Powered by Mantis Bugtracker
