0005197 | ParaView | (No Category) | public | 2007-06-15 10:43 | 2007-08-29 12:06 | ||||
Reporter | Amy Squillacote | ||||||||
Assigned To | Dave DeMarle | ||||||||
Summary | 0005197: pvpython Fetch and multi-block data | ||||||||
Description | When multi-block / composite data is loaded using pvpython, Fetch does not return real data. The dataset returned from Fetch has the type of one of the sub-blocks, but it's empty (no cells, points, attribute data, etc.). In the attached python script that demonstrates this problem, the DataDir should be set to VTKData (not ParaViewData). | ||||||||
Attached Files | VRMLSource.py [^] (707 bytes) 1969-12-31 19:00 | ||||||||
(0007963) user521 2007-06-29 12:03 |
Committed changes to fetch, vtkCommunicator, vtkclientserverdeliver and vtkReductionFilter on 6-26 and 6-28 to deliver composite data properly. I have not finished verifying it so I will not mark this as resolved yet. |
(0008725) Dave DeMarle (administrator) 2007-08-28 16:35 |
I finished Fetch for vtkCompositeDataSets on 2007-08-09. |
2007-08-28 16:35 | Dave DeMarle | Note Added: 0008725 | |
2007-08-28 16:37 | Dave DeMarle | Status | tabled => @80@ |
2007-08-28 16:37 | Dave DeMarle | Category | => 3.2 |
2007-08-29 12:06 | Ken Moreland | Status | @80@ => closed |
