0005076 | ParaView | (No Category) | public | 2007-05-22 12:57 | 2009-05-13 13:59 | ||||
Reporter | Amy Squillacote | ||||||||
Summary | 0005076: Surface Flow filter doesn't work with multi-block data | ||||||||
Description | To reproduce this behavior, do the following. Load combxyz.bin/comb.bin PLOT3D dataset. Apply a Cut filter to this. In the Filter menu, the Surface Flow filter is not available. Somehow this worked in PV 2.6 because I came across this trying to duplicate the Flow.pvs test from the PV26 repository. | ||||||||
Attached Files | SurfaceFlow.JPG [^] (163,821 bytes) 2008-06-09 21:02
(0011846) Alan Scott (manager) 2008-05-12 20:49 |
Berk, I cannot replicate your fix. The Surface Flow filter is still not available. Am I doing something wrong? alan |
(0012218) Utkarsh Ayachit (administrator) 2008-06-03 11:15 |
This time it's really fixed :) |
(0012297) Alan Scott (manager) 2008-06-09 21:01 |
I still cannot replicate this. After bringing up combxyz.bin with the PLOT3D data file reader, then applying a Slice filter, the Surface Flow filter is grayed out. Should it be grey (and the bug rejected), or should it be black, thus still needs fixing? Tested local XP client, nightly trunk, afternoon of June 9th pull. |
(0012298) Alan Scott (manager) 2008-06-09 21:01 |
Attaching a screen shot of the filters. |
(0012379) Utkarsh Ayachit (administrator) 2008-06-17 15:24 |
I just verified that this works. I am able to apply the SurfaceFlow filter on the output of the slice filter (local, parallel). Are you sure you also loaded the "Q" file? Make sure that the "Q File Name" is set to the "combq.bin" file in the reader properties. |
(0012482) Alan Scott (manager) 2008-06-23 20:47 |
Ah, Utkarsh was right. The last problem was tester's error. Tested client/server. |
2008-04-09 20:49 | Berk Geveci | Category | => 3.4 |
2008-05-08 14:06 | Berk Geveci | Status | tabled => @80@ |
2008-05-08 14:06 | Berk Geveci | Resolution | open => fixed |
2008-05-12 20:49 | Alan Scott | Status | @80@ => @20@ |
2008-05-12 20:49 | Alan Scott | Resolution | fixed => reopened |
2008-05-12 20:49 | Alan Scott | Note Added: 0011846 | |
2008-06-03 11:15 | Utkarsh Ayachit | Status | @20@ => @80@ |
2008-06-03 11:15 | Utkarsh Ayachit | Resolution | reopened => fixed |
2008-06-03 11:15 | Utkarsh Ayachit | Note Added: 0012218 | |
2008-06-09 21:01 | Alan Scott | Assigned To | Berk Geveci => Utkarsh Ayachit |
2008-06-09 21:01 | Alan Scott | Status | @80@ => @20@ |
2008-06-09 21:01 | Alan Scott | Resolution | fixed => reopened |
2008-06-09 21:01 | Alan Scott | Note Added: 0012297 | |
2008-06-09 21:01 | Alan Scott | Note Added: 0012298 | |
2008-06-09 21:02 | Alan Scott | File Added: SurfaceFlow.JPG | |
2008-06-11 07:12 | Utkarsh Ayachit | Status | @20@ => tabled |
2008-06-11 07:12 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Berk Geveci |
2008-06-11 07:13 | Utkarsh Ayachit | Assigned To | Berk Geveci => Utkarsh Ayachit |
2008-06-17 15:24 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-06-17 15:24 | Utkarsh Ayachit | Resolution | reopened => fixed |
2008-06-17 15:24 | Utkarsh Ayachit | Note Added: 0012379 | |
2008-06-23 20:47 | Alan Scott | Status | @80@ => closed |
2008-06-23 20:47 | Alan Scott | Note Added: 0012482 | |
