0005065 | VTK | (No Category) | public | 2007-05-21 01:31 | 2016-08-12 09:54 | ||||
Reporter | Andrew Maclean | ||||||||
Assigned To | Will Schroeder | ||||||||
Summary | 0005065: Build debug and release libs/dlls to the same directory. | ||||||||
Description | An option to build/install debug and release libs/dlls to the same directory. I think this can be easily done by changging: <VTK_DIR>\Cmake\KitCommonBlock.cmake From: IF(VTK_LIBRARY_PROPERTIES) SET_TARGET_PROPERTIES(${KIT_LIBRARY_TARGETS} PROPERTIES ${VTK_LIBRARY_PROPERTIES} ) ENDIF(VTK_LIBRARY_PROPERTIES) to: IF(VTK_LIBRARY_PROPERTIES) SET_TARGET_PROPERTIES(${KIT_LIBRARY_TARGETS} PROPERTIES ${VTK_LIBRARY_PROPERTIES} ) #Add this line to change the output debug library name to *_d.lib/.dll SET_TARGET_PROPERTIES(${KIT_LIBRARY_TARGETS} PROPERTIES DEBUG_POSTFIX _d ) ENDIF(VTK_LIBRARY_PROPERTIES) This is documented at the following URL: http://www.vesuite.org/forum/viewtopic.php?=&p=341 [^] Can this be extended to include an option to add the _d extension automatically when building VTK? The rationale is that when building your own code it would be nice to automatically include either the debug or release versions as appropriate. | ||||||||
(0036913) Kitware Robot (administrator) 2016-08-12 09:54 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2016-08-12 09:54 | Kitware Robot | Note Added: 0036913 | |
2016-08-12 09:54 | Kitware Robot | Status | expired => closed |
2016-08-12 09:54 | Kitware Robot | Resolution | open => moved |
