0004731 | ParaView | (No Category) | public | 2007-03-30 16:46 | 2009-05-13 13:59 | ||||
Reporter | David Karelitz | ||||||||
Summary | 0004731: Slice default name in pipeline browser defaults to Cut | ||||||||
Description | The Slice filter default name in the pipeline browser is Cut# and not Slice# | ||||||||
(0007025) Berk Geveci (administrator) 2007-03-30 23:10 |
I am sorry but this is not a level 4 bug. Compared to even some of the level 3 bugs we have, this should be a lower priority. |
(0008600) Berk Geveci (administrator) 2007-08-23 09:46 |
Make sure that backwards compatibility is preserved when making this change. |
(0012215) Utkarsh Ayachit (administrator) 2008-06-03 11:00 |
Use the proxy label to decide the default name. |
(0012288) Utkarsh Ayachit (administrator) 2008-06-06 13:42 |
Proxy label, instead of proxy xml name, is used to determine default name that appears in the pipeline brower. /cvsroot/ParaView3/ParaView3/Qt/Core/pqObjectBuilder.cxx,v <-- Qt/Core/pqObjectBuilder.cxx new revision: 1.26; previous revision: 1.25 |
(0012299) Alan Scott (manager) 2008-06-09 21:04 |
Tested local client. |
2007-08-23 09:46 | Berk Geveci | Note Added: 0008600 | |
2008-04-08 16:25 | Berk Geveci | Category | => 3.4 |
2008-06-03 10:59 | Utkarsh Ayachit | Assigned To | Berk Geveci => Utkarsh Ayachit |
2008-06-03 11:00 | Utkarsh Ayachit | Note Added: 0012215 | |
2008-06-06 13:42 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-06-06 13:42 | Utkarsh Ayachit | Resolution | open => fixed |
2008-06-06 13:42 | Utkarsh Ayachit | Note Added: 0012288 | |
2008-06-09 21:04 | Alan Scott | Status | @80@ => closed |
2008-06-09 21:04 | Alan Scott | Note Added: 0012299 | |
