0004666 | ParaView | (No Category) | public | 2007-03-23 15:16 | 2009-05-13 13:59 | ||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Summary | 0004666: Make light kit default | ||||||||
Description | The light kit set of lights should be on by default and the "default light" should be off by default. And since the naming sounds weird, on the pq3DViewPropertiesWidget, the "Default Light" label should be changed to "Headlight" and the "Light Kit Parameters" label should be changed to simply be "Light Kit". | ||||||||
(0011872) Utkarsh Ayachit (administrator) 2008-05-13 14:51 |
Make light kit default. Changed widget labels. Fixed tests to disable light kit and added a test with light kit enabled. ------------------------- commitid: nviKJZ6f0bhjRP2t ------------------------- /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderView.cxx,v <-- Qt/Core/pqRenderView.cxx new revision: 1.35; previous revision: 1.34 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- Servers/ServerManager/Resources/rendering.xml new revision: 1.287; previous revision: 1.286 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/Cxx/ManualConnectBuiltin.xml.in,v <-- Applications/Client/Testing/Cxx/ManualConnectBuiltin.xml.in new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/Cxx/ManualConnectCRSDS.xml.in,v <-- Applications/Client/Testing/Cxx/ManualConnectCRSDS.xml.in new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/Cxx/ManualConnectCRSDSRR.xml.in,v <-- Applications/Client/Testing/Cxx/ManualConnectCRSDSRR.xml.in new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/Cxx/ManualConnectCS.xml.in,v <-- Applications/Client/Testing/Cxx/ManualConnectCS.xml.in new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/Cxx/ManualConnectCSRR.xml.in,v <-- Applications/Client/Testing/Cxx/ManualConnectCSRR.xml.in new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/XdmfReadImageData.xml,v <-- Applications/Client/Testing/XML/XdmfReadImageData.xml new revision: 1.3; previous revision: 1.2 |
(0011936) Alan Scott (manager) 2008-05-14 19:35 |
Using this morning's trunk, when I go Edit/ View Settings/ Lights, and hit the Reset button, it defaults to "Default Light". Shouldn't this reset to Light Kit, as stated below? Also, it still shows "Light Kit Parameters" |
(0011990) Utkarsh Ayachit (administrator) 2008-05-19 09:41 |
Reset button resets lights correcly /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderView.cxx,v <-- Qt/Core/pqRenderView.cxx new revision: 1.36; previous revision: 1.35 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderView.h,v <-- Qt/Core/pqRenderView.h new revision: 1.19; previous revision: 1.18 |
(0012057) Alan Scott (manager) 2008-05-21 22:28 |
Shouldn't the reset light button actually reset the numbers to a default? I change the Key/ Warm entry box from 0.60 to 0.70, hit reset light, and nothing happens. Client/Server. |
(0012556) Utkarsh Ayachit (administrator) 2008-06-27 09:58 |
Reset Light resets light parameters. It was resetting only the changed property values. /cvsroot/ParaView3/ParaView3/Qt/Components/pqRenderViewOptions.cxx,v <-- Qt/Components/pqRenderViewOptions.cxx new revision: 1.6; previous revision: 1.5 |
(0012590) Alan Scott (manager) 2008-06-30 19:57 |
Tested client/server. |
2008-04-08 16:22 | Berk Geveci | Assigned To | Berk Geveci => Ken Moreland |
2008-04-08 16:22 | Berk Geveci | Assigned To | Ken Moreland => Utkarsh Ayachit |
2008-04-08 16:23 | Berk Geveci | Category | => 3.4 |
2008-05-13 14:51 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-05-13 14:51 | Utkarsh Ayachit | Resolution | open => fixed |
2008-05-13 14:51 | Utkarsh Ayachit | Note Added: 0011872 | |
2008-05-14 19:35 | Alan Scott | Status | @80@ => @20@ |
2008-05-14 19:35 | Alan Scott | Resolution | fixed => reopened |
2008-05-14 19:35 | Alan Scott | Note Added: 0011936 | |
2008-05-19 09:41 | Utkarsh Ayachit | Status | @20@ => @80@ |
2008-05-19 09:41 | Utkarsh Ayachit | Resolution | reopened => fixed |
2008-05-19 09:41 | Utkarsh Ayachit | Note Added: 0011990 | |
2008-05-21 22:28 | Alan Scott | Status | @80@ => @20@ |
2008-05-21 22:28 | Alan Scott | Resolution | fixed => reopened |
2008-05-21 22:28 | Alan Scott | Note Added: 0012057 | |
2008-06-27 09:58 | Utkarsh Ayachit | Status | @20@ => @80@ |
2008-06-27 09:58 | Utkarsh Ayachit | Resolution | reopened => fixed |
2008-06-27 09:58 | Utkarsh Ayachit | Note Added: 0012556 | |
2008-06-30 19:57 | Alan Scott | Status | @80@ => closed |
2008-06-30 19:57 | Alan Scott | Note Added: 0012590 | |
