0004323 | ParaView | Bug | public | 2007-01-16 10:58 | 2016-08-12 09:57 | ||||
Reporter | David Karelitz | ||||||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Summary | 0004323: Programmable Filter Text Editor | ||||||||
Description | Is it possible to switch the Text Editor for the Programmable Filter to a monospace font and make tabs insert 4 spaces? Tab auto-indent would be nice, but I'm not sure that can be done. | ||||||||
(0006768) Berk Geveci (administrator) 2007-03-13 15:21 |
I already changed the tab spacing. Changing the font should be easy. |
(0006769) Berk Geveci (administrator) 2007-03-13 15:21 |
It would also be nice have an Insert File functionality. |
(0007273) Berk Geveci (administrator) 2007-04-13 09:08 |
I believe I fixed the font and indentation (no auto-indent though, it is hard to implement) |
(0011359) Clinton Stimpson (developer) 2008-04-15 16:56 |
Now it has a fixed width font. /cvsroot/ParaView3/ParaView3/Qt/Components/pqNamedWidgets.cxx,v <-- pqNamedWidgets.cxx new revision: 1.45; previous revision: 1.44 What's left? Auto-indenting, insert file, or both? |
(0012149) Berk Geveci (administrator) 2008-05-29 13:20 |
We should at least keep the same indentation as the previous line. |
(0015014) Utkarsh Ayachit (administrator) 2009-02-17 10:49 |
Preserve the indentation of the previous line. /cvsroot/ParaView3/ParaView3/Qt/Python/pqPythonShell.cxx,v <-- Qt/Python/pqPythonShell.cxx new revision: 1.19; previous revision: 1.18 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqConsoleWidget.cxx,v <-- Qt/Widgets/pqConsoleWidget.cxx new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqConsoleWidget.h,v <-- Qt/Widgets/pqConsoleWidget.h new revision: 1.7; previous revision: 1.6 |
(0015174) Alan Scott (manager) 2009-02-18 16:41 |
As per our conversation, you need to also work on the programmable filter. Since the bug is a bit unclear on specifics, please let me know what you did so I can test it. |
(0037507) Kitware Robot (administrator) 2016-08-12 09:57 |
2008-04-07 16:39 | Berk Geveci | Assigned To | Dave DeMarle => Clinton Stimpson |
2008-04-07 16:39 | Berk Geveci | Category | => 3.4 |
2008-04-15 16:56 | Clinton Stimpson | Note Added: 0011359 | |
2008-05-29 13:20 | Berk Geveci | Note Added: 0012149 | |
2008-05-29 13:20 | Berk Geveci | Category | 3.4 => 3.6 |
2009-02-16 14:46 | Ken Moreland | Assigned To | Clinton Stimpson => Utkarsh Ayachit |
2009-02-17 10:49 | Utkarsh Ayachit | Note Added: 0015014 | |
2009-02-17 10:49 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-02-17 10:49 | Utkarsh Ayachit | Resolution | open => fixed |
2009-02-18 16:41 | Alan Scott | Note Added: 0015174 | |
2009-02-18 16:41 | Alan Scott | Status | @80@ => @20@ |
2009-02-18 16:41 | Alan Scott | Resolution | fixed => reopened |
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
2009-08-25 18:46 | Utkarsh Ayachit | Category | => Bug |
2009-08-25 18:46 | Utkarsh Ayachit | Target Version | 3.6 => 3.8 |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037507 | |
2016-08-12 09:57 | Kitware Robot | Resolution | reopened => moved |
