0004278 | ParaView | (No Category) | public | 2007-01-04 11:35 | 2007-04-16 13:34 | ||||
Reporter | David Karelitz | ||||||||
Summary | 0004278: Exodus Metadata does not work correctly | ||||||||
Description | The Exodus metadata tabs (Blocks/Hierarchy/Materials) do not function correctly. The problem is that the values for all those settings are linked, so a change to one of them may results in changes to all the others. For example, if I toggle off an Assembly, the value of blocks, materials, and other assemblies may change. Currently only the reader is aware of these links, so after a setting is changed the reader needs to be queried for new values of all these settings. | ||||||||
(0006845) Clinton Stimpson (developer) 2007-03-19 17:38 |
/cvsroot/ParaView3/ParaView3/Qt/Components/pqExodusPanel.cxx,v <-- pqExodusPanel.cxx new revision: 1.18; previous revision: 1.17 /cvsroot/ParaView3/ParaView3/Qt/Components/pqExodusPanel.h,v <-- pqExodusPanel.h new revision: 1.13; previous revision: 1.12 |
(0006860) Ken Moreland (manager) 2007-03-20 12:13 |
I just asked Dave Karelitz about the status of this bug. He states: "This is still very broken. Now you can't even turn off a block." |
(0006869) Clinton Stimpson (developer) 2007-03-20 17:07 |
For sake of short term usability, I reverted the last fix. The root of that problem is 3 SM properties modifying the same data in vtkExodusReader. In the recent case, the Material selection always won because it was the last to tell vtkExodusReader what materials are on/off. |
(0006885) Clinton Stimpson (developer) 2007-03-21 16:07 |
/cvsroot/ParaView3/ParaView3/Qt/Components/pqExodusPanel.cxx,v <-- pqExodusPanel.cxx new revision: 1.20; previous revision: 1.19 /cvsroot/ParaView3/ParaView3/Qt/Components/pqExodusPanel.h,v <-- pqExodusPanel.h new revision: 1.15; previous revision: 1.14 Fixed. You can switch between block/material/hierarchy selections and and (un)select items and they stay in sync even before hitting accept. |
(0007257) David Karelitz (reporter) 2007-04-12 11:41 |
Looks like this is broken again. If you hit the toggle all blocks on/off checkbox, the assemblies and materials lists do not update. |
(0007258) Clinton Stimpson (developer) 2007-04-12 12:39 |
/cvsroot/ParaView3/ParaView3/Qt/Components/pqExodusPanel.cxx,v <-- pqExodusPanel.cxx new revision: 1.30; previous revision: 1.29 Fixed. |
