0004215ParaView(No Category)public2006-12-15 16:162010-11-30 21:30
ReporterJeff Baumes
Assigned ToBerk Geveci
PrioritylowSeverityfeatureReproducibilityalways
StatusclosedResolutionwon't fix
PlatformOSOS Version
Product Version
Target VersionSomedayFixed in Version
Summary0004215: ParaView uses legacy readers which are big endian
DescriptionSince nearly all modern computers are little endian, it is unfortunate that the legacy binary readers/writers always use big endian format. ParaView uses this format for transferring data, so this causes byte-swapping on the sending and receiving end. It would be better if the data could be sent in little endian format, or the user could choose whether to send in little or big endian format.
TagsNo tags attached.
Project
Topic Name
Type
 Relationships
  Notes
(0011118)
Berk Geveci (administrator)
2008-04-07 16:28
Is this overhead significant compared to network transfer?
(0011227)
Jeff Baumes (administrator)
2008-04-09 16:55
That's unknown.
(0023557)
David Partyka (developer)
2010-11-26 14:31
I think the only option is to use the xml readers/writers.
(0023600)
Alan Scott (manager)
2010-11-30 21:30
I agree that this bug should be closed. I suspect that the time spent swapping bytes is orders of magnitude less than the necessary time just loading and storing the data itself. If you disagree, feel free to bring it up on the mailing list or open a new bug.
 Issue History
2008-04-07 16:28 Berk Geveci Note Added: 0011118
2008-04-08 16:29 Berk Geveci Category => Someday
2008-04-09 16:55 Jeff Baumes Note Added: 0011227
2009-05-13 13:49 Utkarsh Ayachit Target Version => Someday
2010-11-26 14:31 David Partyka Note Added: 0023557
2010-11-26 14:31 David Partyka Status tabled => @80@
2010-11-26 14:31 David Partyka Resolution open => won't fix
2010-11-30 21:30 Alan Scott Note Added: 0023600
2010-11-30 21:30 Alan Scott Status @80@ => closed
