0003829 | VTK | (No Category) | public | 2006-09-30 10:19 | 2012-12-12 12:11 | ||||
Reporter | kdsfinger | ||||||||
Assigned To | David Gobbi | ||||||||
Priority | urgent | Severity | minor | Reproducibility | always | ||||
Target Version | Fixed in Version | 5.8 | |||||||
Summary | 0003829: vtkImageActor won't show color image if previously setinput grayscale image | ||||||||
Description | The vtkImageActor won't be able to display color image if it was setinput for a grayscale image previously. It will only show one channel of the color image as if it is a grayscale image. vtk_actor.SetInput(grayscaleImageData); //the vtk_actor will display grayscale image correctly vtk_actor.SetInput(colorImageData); //the vtk_actor will display the color image in grayscale //no matter how you switch the color/grayscale image, the vtk_actor will always display in grayscale. However, if we do vtk_actor.SetInput(colorImageData); //the vtk_actor will display color image correctly vtk_actor.SetInput(grayscaleImageData); //the vtk_actor will display grayscale image correctly //now matter how you switch color/grayscale image, the vtk_actor will always display them correctly. //the vtk_actor will display color image This problem is observed on the newest vtk 5.1 | ||||||||
(0005072) kdsfinger (reporter) 2006-09-30 10:30 |
The line next to the last ("//the vtk_actor will display color image") should be deleted. What I want to say is that if we setinput with a color image, then everything is correct no matter how you switch between grayscale/color later on. |
(0025588) David Gobbi (developer) 2011-02-26 10:37 |
This issue has been fixed in VTK 5.8. |
2008-02-06 10:50 | Jeff Baumes | Assigned To | Will Schroeder => Sebastien Barre |
2008-02-06 10:50 | Jeff Baumes | Severity | major => minor |
2011-02-26 10:37 | David Gobbi | Note Added: 0025588 | |
2011-02-26 10:37 | David Gobbi | Status | tabled => @80@ |
2011-02-26 10:37 | David Gobbi | Resolution | open => fixed |
2011-02-26 10:37 | David Gobbi | Assigned To | Sebastien Barre => David Gobbi |
2012-12-12 12:11 | David Gobbi | Status | customer review => closed |
2012-12-12 12:11 | David Gobbi | Fixed in Version | => 5.8 |
