0003825 | VTK | (No Category) | public | 2006-09-29 05:02 | 2016-08-12 09:54 | ||||
Reporter | Jean Favre | ||||||||
Priority | low | Severity | major | Reproducibility | always | ||||
Summary | 0003825: clipdataset crashes on hexa grid | ||||||||
Description | This is a bug I found using ParaView CVS, When clipping with the default sphere widget settings, clipping works fine. If changing InsideOut=ON without changing anything else, paraview crashes here is the Tcl script showing the bug on my Linux box: vtkXMLUnstructuredGridReader reader reader SetFileName /local1/data/hexasc0.vtu vtkSphere sphere sphere SetRadius 1.66 sphere SetCenter 1.66 1.66 1.66 vtkClipDataSet clip clip SetInputConnection [reader GetOutputPort] clip InsideOutOn clip SetClipFunction sphere clip Update | ||||||||
Attached Files | hexasc0.vtu.gz [^] (0 bytes) 1969-12-31 19:00 | ||||||||
(0010481) Berk Geveci (administrator) 2008-02-13 13:46 |
Unfortunately, it seems like the data file did not survive the transfer from the phpbugtracker. Jean, do you still have this file somewhere? |
(0010742) Berk Geveci (administrator) 2008-03-06 19:01 |
Reminder sent to: Jean Favre Jean, Do you still have this dataset? |
(0036888) Kitware Robot (administrator) 2016-08-12 09:54 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2008-02-06 10:51 | Jeff Baumes | Assigned To | Will Schroeder => Berk Geveci |
2008-02-13 13:46 | Berk Geveci | Note Added: 0010481 | |
2008-03-06 19:01 | Berk Geveci | Note Added: 0010742 | |
2016-08-12 09:54 | Kitware Robot | Note Added: 0036888 | |
2016-08-12 09:54 | Kitware Robot | Status | expired => closed |
2016-08-12 09:54 | Kitware Robot | Resolution | open => moved |
