0003685 | VTK | (No Category) | public | 2006-08-31 15:58 | 2016-08-12 09:54 | ||||
Reporter | Shang Mu | ||||||||
Assigned To | Will Schroeder | ||||||||
Summary | 0003685: vtkRenderWindowInteractor / vtkOpenGLVolumeTextureMapper3D bug? | ||||||||
Description | I'm volume rendering a 3D image read from DICOM sequence using vtkOpenGLVolumeTextureMapper3D, and the window is a vtkRenderWindowInteractor. When I use camera mode, the interactor works fine (generally smooth with a little lag), but if I switch to actor mode and move the actor, it takes more than half a minute to render a scene. Is it a bug or some implementation limitation? I'm using wxPython under Windows, so the class I used is actually wxVTKRenderWindowInteractor. This should not be the point though. | ||||||||
(0036886) Kitware Robot (administrator) 2016-08-12 09:54 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2016-08-12 09:54 | Kitware Robot | Note Added: 0036886 | |
2016-08-12 09:54 | Kitware Robot | Status | expired => closed |
2016-08-12 09:54 | Kitware Robot | Resolution | open => moved |
