0000328ParaView(No Category)public2003-11-04 15:512009-12-10 20:29
ReporterCharles Law
Assigned To
PriorityhighSeverityfeatureReproducibilityunable to reproduce
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Summary0000328: User must specify to much info for an animation
DescriptionI called this a bug since it seems obvious that it should be done better.
Upon requesting an animation the 'Start Value' and 'End Value' should be the first and last time step contained in the file. This can then be modified by the user. Also, if the user specifies time steps which are out of range, they should be clamped the min and max available time steps.
Currently (on linux at least) the defaults time steps for animation are 0 and 100.
Also, the default 'Source' should be something reasonable, like the first source in the pipeline. And the default 'Parameter' should be 'Time Step'. Both could of course, be changed later.
TagsNo tags attached.
Project
Topic Name
Type
 Relationships
  Notes
(0000352)
Berk Geveci (administrator)
2003-12-17 12:30
animation editor should be improved. widget ranges have to work better.
 Issue History
2007-08-28 13:05 Zack Galbreath Assigned To Terry Gerts =>
2007-08-28 13:05 Zack Galbreath Severity minor => feature
2007-08-28 13:05 Zack Galbreath Status @80@ => @30@
2007-08-28 13:05 Zack Galbreath Resolution unable to reproduce => open
2007-08-28 13:05 Zack Galbreath Summary Goodsite => User must specify to much info for an animation
2007-08-28 13:06 Zack Galbreath Note Deleted: 0008296
2007-08-28 13:06 Zack Galbreath Project @18@ => @3@
2009-12-09 14:49 Berk Geveci Project @3@ => ParaView
2009-12-10 20:29 Berk Geveci Status @30@ => closed
2009-12-10 20:29 Berk Geveci Resolution open => fixed
2011-06-16 13:09 Zack Galbreath Category => (No Category)
