0003148 | ParaView | (No Category) | public | 2006-04-19 19:07 | 2006-11-22 16:52 | ||||
Reporter | David Rogers | ||||||||
Summary | 0003148: 'current variable' update bug | ||||||||
Description | After setting the 'current variable' using the current variable combo box in the top toolbar, the corresponding filter (in my case, it was an Exodus Reader) does not reflect that change. To reproduce this, open an Exodus file. Select a variable with the 'current variable' combo box. The Exodus Reader should update to show the variable has been loaded (the variable's checkbox should be checked.) | ||||||||
(0004595) Clinton Stimpson (developer) 2006-08-01 18:14 |
The variable selector doesn't show unloaded arrays anymore, so this seems to not apply. |
