0002886ParaViewBugpublic2006-02-15 09:072015-01-09 14:06
ReporterChristian Becker
Assigned ToBerk Geveci
PrioritylowSeverityminorReproducibilityalways
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target VersionFixed in Version3.14
Summary0002886: AVS UCD reader doesn't recognize comment lines
DescriptionIf AVS ucd files with comment lines (symbol #)
are used, the reader doesn't recognize the
file information without any error message.
TagsNo tags attached.
Project
Topic Name
Type
Attached Files? file icon cellsnd.ascii.reader-chokes-on-empty-comment.inp [^] (1,171 bytes) 2011-06-29 15:44
? file icon cellsnd.ascii.reader-chokes-on-excessive-comment-length.inp [^] (1,271 bytes) 2011-06-29 15:44
patch file icon 0001-BUG-Fix-for-BUG-2886.-AVS-UCD-reader-could-choke-on-.patch [^] (1,356 bytes) 2011-06-29 15:45 [Show Content]
 Relationships
  Notes
(0026914)
Sven Buijssen (reporter)
2011-06-29 15:42
I'm familiar with the issue the original reporter tried to explain and will try to be more specific:
The reader silently chokes on
1) empty comment lines (i.e. comment character in column 1 and no trailing white space)
2) comment lines of excessive length (i.e. > 100 characters)
1) is due to
      this->FileStream->get(buf, 100, '\n');
in vtkAVSucdReader.cxx:226 setting the failbit flag as soon as an empty comment line is found. Subsequent parsing then fails due to !this->FileStream->good()
In both cases subsequent attempts to read the number of nodes/cells/node fields etc. set all of these variables to zero such that the user ends up with no data being imported at all.
I'll attach an example file for either case (both files are derived from VTK_Data/Data/cellsnd.ascii.inp) and a suggested patch.
(0028325)
2012-02-28 04:26
c1fd00a BUG: Fix for BUG 0002886. AVS UCD reader could choke on comments
 Issue History
2009-12-09 14:51 Berk Geveci Project @3@ => ParaView
2009-12-09 17:22 Berk Geveci Priority normal => low
2009-12-09 17:22 Berk Geveci Category => Bug
2011-06-29 15:42 Sven Buijssen Note Added: 0026914
2011-06-29 15:44 Sven Buijssen File Added: cellsnd.ascii.reader-chokes-on-empty-comment.inp
2011-06-29 15:44 Sven Buijssen File Added: cellsnd.ascii.reader-chokes-on-excessive-comment-length.inp
2011-06-29 15:45 Sven Buijssen File Added: 0001-BUG-Fix-for-BUG-2886.-AVS-UCD-reader-could-choke-on-.patch
2012-02-28 04:26 Sven Buijssen Note Added: 0028325
2012-02-28 04:26 Sven Buijssen Status expired => closed
2012-02-28 04:26 Sven Buijssen Resolution open => fixed
2012-02-28 04:26 Sven Buijssen Fixed in Version => 3.14
2015-01-09 14:04 Robert Maynard Source_changeset_attached => VTK master 69dd488d
2015-01-09 14:04 Robert Maynard Source_changeset_attached => VTK master c1fd00a2
2015-01-09 14:06 Utkarsh Ayachit Source_changeset_attached => VTK master 55be43b6
