0002571 | ParaView | (No Category) | public | 2005-12-06 16:38 | 2006-11-22 16:28 | ||||
Reporter | Clinton Stimpson | ||||||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Summary | 0002571: file->new twice causes abort | ||||||||
Description | not sure if this is a bug in pqServer or if the server manager doesn't support it | ||||||||
(0003363) 2005-12-06 18:08 |
Not able to reproduce this, if I create two new connections, I get a warning message "Warning: In \src\ParaQ\ParaView\Vtk\Parallel\vtkSocketController.cxx, line 63 vtkSocketController (0546C3B8): Already initialized.", but the app continues to work. |
(0003364) Timothy Shead (reporter) 2005-12-06 18:09 |
(0003382) Clinton Stimpson (developer) 2005-12-08 17:48 |
Its a memory error in the GUI. Looks like a bug in Qt which affects the object hierarchy view. |
(0003383) Mark Richardson (reporter) 2005-12-09 11:35 |
There is a bug in the Qt object model. If you remove an item with a sub-item selected, it does not remove the persistant index for the selection. Later, it asks for the parent of the removed, and deleted, object. I haven't tried Qt 4.1, but there was supposed to be a fix for this. If not we may be able to work around it be deselecting the sub-item before removing it. |
(0003885) Mark Richardson (reporter) 2006-03-20 17:47 |
Qt 4.1 does fix the crash in the selection model. |
