0002178 | VTK | (No Category) | public | 2005-08-22 17:28 | 2016-08-12 09:54 | ||||
Reporter | lee ann fisk | ||||||||
Assigned To | Will Schroeder | ||||||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Summary | 0002178: Two build/install problems VTK/Mangled MESA | ||||||||
Description | I just built VTK (a recent nightly) on my Linux machine with MANGLED_MESA and Mesa 6.3.2. In the Rendering/vtkgl.h file that gets created, I had to add this line: #ifdef VTK_USE_X #define GLX_GLXEXT_PROTOTYPES // I added this #include <GL/glx.h> #endif Without it, Mesa's glxext.h would not declare glXGetProcAddressARB, and vtkOpenGLExtensionManager.cxx wouldn't compile. Maybe this is not the proper fix, but it worked for me. Also, I had to copy the created MangleMesaInclude directory and its contents to my installed "include" directory. It didn't get copied there with "gmake install", and my application wouldn't build without it. Everything works fine now. | ||||||||
(0036797) Kitware Robot (administrator) 2016-08-12 09:54 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2016-08-12 09:54 | Kitware Robot | Note Added: 0036797 | |
2016-08-12 09:54 | Kitware Robot | Status | expired => closed |
2016-08-12 09:54 | Kitware Robot | Resolution | open => moved |
