0016130 | VTK | (No Category) | public | 2016-05-18 02:22 | 2016-07-06 10:46 | ||||
Reporter | Marc Mörig | ||||||||
Assigned To | David Gobbi | ||||||||
Target Version | Fixed in Version | 7.1.0 | |||||||
Summary | 0016130: crashes in vtkImageSliceCollection | ||||||||
Description | Certain combinations of layer numbers/insertion order lead to inconsistencies in internal data of vtkImageSliceCollection / vtkCollection, which leads to crashes upon further usage of the collection. I have attached code that demonstrates the issue. The problem is, that the Bottom member of vtkCollection does not get updated correctly in all cases in vtkImageSliceCollection::AddItem(...). The following patch resolves the problem. diff --git a/Rendering/Image/vtkImageSliceCollection.cxx b/Rendering/Image/vtkImageSliceCollection.cx index e33f93c..6018cbb 100644 --- a/Rendering/Image/vtkImageSliceCollection.cxx +++ b/Rendering/Image/vtkImageSliceCollection.cxx @@ -69,6 +69,7 @@ void vtkImageSliceCollection::AddItem(vtkImageSlice *a) elem->Next = indexElem->Next; indexElem->Item = a; indexElem->Next = elem; + if(this->Bottom == indexElem) this->Bottom = elem; this->NumberOfItems++; a->Register(this); return; | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
Attached Files | crash_vtkImageSliceCollection.cpp [^] (1,479 bytes) 2016-05-18 02:22 | ||||||||
(0035988) Marc Mörig (reporter) 2016-05-18 02:25 |
I should mention that at least VTK 7.0 is affected. |
(0035998) David Gobbi (developer) 2016-05-20 13:44 |
https://gitlab.kitware.com/vtk/vtk/merge_requests/1513 [^] |
(0036006) David Gobbi (developer) 2016-05-24 17:06 |
This has been merged into master, but I'm not closing yet because it should also be merged into VTK 6.3.1. |
2016-05-18 02:22 | Marc Mörig | New Issue | |
2016-05-18 02:22 | Marc Mörig | File Added: crash_vtkImageSliceCollection.cpp | |
2016-05-18 02:25 | Marc Mörig | Note Added: 0035988 | |
2016-05-18 13:18 | David Gobbi | Assigned To | => David Gobbi |
2016-05-20 13:44 | David Gobbi | Note Added: 0035998 | |
2016-05-20 13:44 | David Gobbi | Status | backlog => gerrit review |
2016-05-24 17:06 | David Gobbi | Note Added: 0036006 | |
2016-07-06 10:46 | David Gobbi | Status | gerrit review => closed |
2016-07-06 10:46 | David Gobbi | Resolution | open => fixed |
2016-07-06 10:46 | David Gobbi | Fixed in Version | => 7.1.0 |
