0016111 | ParaView | (No Category) | public | 2016-05-05 23:21 | 2016-06-30 15:10 | ||||
Reporter | Cory Quammen | ||||||||
Assigned To | Cory Quammen | ||||||||
Target Version | Fixed in Version | 5.1 | |||||||
Summary | 0016111: Frontface culling of surfaces disables volume rendering | ||||||||
Description | Volume rendering of image data disappears when a surface is rendered with frontface culling is on. When the surface is removed, volume rendering is still missing. | ||||||||
Steps To Reproduce | - run paraview, built-in server - add Wavelet, switch to Volume representation - add another Wavelet, switch to Surface representation - set Backface Representation of second Wavelet to Cull Frontface. The volume rendering disappears - turn off the visibility of the second wavelet. The volume rendering is still missing. | ||||||||
Project | TBD | ||||||||
Attached Files | VolumeRendering-Bug.png [^] (58,222 bytes) 2016-05-06 14:28
VolumeRendering-NoBug.png [^] (94,008 bytes) 2016-05-06 14:28 | ||||||||
(0035933) Cory Quammen (developer) 2016-05-06 14:24 |
Note that this seems to affect volume rendering of only vtkImageData. vtkUnstructuredGrid volume rendering does not seem to be affected. |
(0035934) Cory Quammen (developer) 2016-05-06 14:26 edited on: 2016-05-06 14:29 |
The Ray Cast Only option (VolumeRendering-NoBug.png) works fine - the GPU based renderer fails (VolumeRendering-Bug.png). |
(0035950) Cory Quammen (developer) 2016-05-13 09:15 |
Fixed by topic https://gitlab.kitware.com/vtk/vtk/merge_requests/1488 [^] |
(0036134) Alan Scott (manager) 2016-06-30 15:10 |
Nice example and test case. Tested Linux, master, remote server. |
2016-05-05 23:22 | Cory Quammen | New Issue | |
2016-05-06 14:20 | Cory Quammen | Note Added: 0035932 | |
2016-05-06 14:24 | Cory Quammen | Note Added: 0035933 | |
2016-05-06 14:26 | Cory Quammen | Note Added: 0035934 | |
2016-05-06 14:28 | Cory Quammen | File Added: VolumeRendering-Bug.png | |
2016-05-06 14:28 | Cory Quammen | File Added: VolumeRendering-NoBug.png | |
2016-05-06 14:29 | Cory Quammen | Note Edited: 0035934 | |
2016-05-06 14:35 | Cory Quammen | Summary | Axes grid disables volume rendering => Frontface culling of surfaces disables volume rendering |
2016-05-06 14:35 | Cory Quammen | Description Updated | |
2016-05-06 14:35 | Cory Quammen | Steps to Reproduce Updated | |
2016-05-06 14:35 | Cory Quammen | Note Deleted: 0035932 | |
2016-05-13 09:15 | Cory Quammen | Note Added: 0035950 | |
2016-05-13 09:15 | Cory Quammen | Status | backlog => gatekeeper review |
2016-05-13 09:15 | Cory Quammen | Fixed in Version | => 5.1 |
2016-05-13 09:15 | Cory Quammen | Resolution | open => fixed |
2016-05-13 09:15 | Cory Quammen | Assigned To | => Cory Quammen |
2016-06-17 00:04 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2016-06-30 15:10 | Alan Scott | Note Added: 0036134 | |
2016-06-30 15:10 | Alan Scott | Status | customer review => closed |
