0016085 | ParaView | (No Category) | public | 2016-04-21 14:29 | 2016-06-09 10:58 | ||||
Target Version | Fixed in Version | 5.1 | |||||||
Summary | 0016085: Using LOD causes slower full-res rendering with OpenGL2 rendering backend | ||||||||
Description | + Open a large geometry file e.g. http://graphics.stanford.edu/data/3Dscanrep/xyzrgb/xyzrgb_statuette.ply.gz [^] + Show as surface and interact. On my machine, if LOD is disabled, then interactions are quite smooth. If LOD is enabled, when one stops interacting, the full-res render takes a long time. I suspect it's rebuilding internal datastructures when toggling between lod-geometry and full-res geometry. | ||||||||
Project | Sandia | ||||||||
(0035914) Utkarsh Ayachit (administrator) 2016-04-21 15:14 |
MR: https://gitlab.kitware.com/paraview/paraview/merge_requests/750 [^] |
(0035980) Alan Scott (manager) 2016-05-17 18:23 |
Nice. Tested local server, works great. Tested remote server, first frame of the LOD is slower than the rest. Thus, I believe it is working correctly. Closing. |
2016-04-21 14:29 | Utkarsh Ayachit | New Issue | |
2016-04-21 15:14 | Utkarsh Ayachit | Note Added: 0035914 | |
2016-04-21 15:14 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2016-04-21 15:14 | Utkarsh Ayachit | Resolution | open => fixed |
2016-04-21 15:14 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2016-04-21 20:54 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2016-04-21 20:54 | Utkarsh Ayachit | Fixed in Version | => git-master |
2016-05-17 18:23 | Alan Scott | Note Added: 0035980 | |
2016-05-17 18:23 | Alan Scott | Status | customer review => closed |
2016-06-09 10:58 | Utkarsh Ayachit | Fixed in Version | git-master => 5.1 |
