0016075 | ParaView | (No Category) | public | 2016-04-15 07:39 | 2016-07-26 19:10 | ||||
Reporter | Mathieu Westphal | ||||||||
Assigned To | Mathieu Westphal | ||||||||
Target Version | Fixed in Version | 5.1 | |||||||
Summary | 0016075: Normal Glyph does not work in some cases | ||||||||
Description | Load maillage_0_0.vtu Call the filter Normal Glyph => It should create a field GlyphVector. Call the filter Glyph with the vector GlyphVector. => It should display the vectors with glyphs. | ||||||||
Project | TBD | ||||||||
Attached Files | maillage_0_0.vtu [^] (50,644 bytes) 2016-04-15 07:39 | ||||||||
(0035887) Mathieu Westphal (developer) 2016-04-15 07:40 |
https://gitlab.kitware.com/paraview/paraview/merge_requests/736 [^] |
(0036585) Alan Scott (manager) 2016-07-25 22:00 |
Don't close without testing. Possible incorrect MR was used. |
(0036600) Mathieu Westphal (developer) 2016-07-26 03:27 |
i will take a look. |
(0036601) Mathieu Westphal (developer) 2016-07-26 03:36 edited on: 2016-07-26 03:39 |
To reproduce the bug (or test the fix) Open Paraview Load Maillage_0_0.vtu Add a NormalGlyphFilter, Make sure the scale is at a correct value (ie 146), Apply |
(0036602) Mathieu Westphal (developer) 2016-07-26 03:41 |
Actually the scaleFactor cannot be computed automaticaly until the filter is executed at least once, but it is not due to this bug, but to the way compound filter and the new arrayScaledExtent Bounds domain works (or not in this case) together |
(0036617) Alan Scott (manager) 2016-07-26 19:10 |
Tested with directions from Notes above. Linux, local server, master. |
2016-04-15 07:39 | Mathieu Westphal | New Issue | |
2016-04-15 07:39 | Mathieu Westphal | Assigned To | => Mathieu Westphal |
2016-04-15 07:39 | Mathieu Westphal | File Added: maillage_0_0.vtu | |
2016-04-15 07:40 | Mathieu Westphal | Note Added: 0035887 | |
2016-04-15 10:13 | Mathieu Westphal | Status | backlog => gatekeeper review |
2016-04-15 10:13 | Mathieu Westphal | Resolution | open => fixed |
2016-06-17 00:06 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2016-06-17 00:06 | Utkarsh Ayachit | Fixed in Version | => 5.1 |
2016-07-25 22:00 | Alan Scott | Note Added: 0036585 | |
2016-07-26 03:27 | Mathieu Westphal | Note Added: 0036600 | |
2016-07-26 03:36 | Mathieu Westphal | Note Added: 0036601 | |
2016-07-26 03:39 | Mathieu Westphal | Note Edited: 0036601 | |
2016-07-26 03:41 | Mathieu Westphal | Note Added: 0036602 | |
2016-07-26 19:10 | Alan Scott | Note Added: 0036617 | |
2016-07-26 19:10 | Alan Scott | Status | customer review => closed |
