0016041 | VTK | (No Category) | public | 2016-03-23 19:24 | 2016-08-12 09:55 | ||||
Reporter | David Gobbi | ||||||||
Assigned To | David Gobbi | ||||||||
Product Version | 7.0.0 | ||||||||
Summary | 0016041: Missing vtkImageSliceMapper functionality for OpenGL2. | ||||||||
Description | Some functionality was lost when the vtkImageSliceMapper moved to OpenGL2: 1) The clipping planes do not work. The clipping planes that are assigned to the slice mapper should be forwarded to the polydata mappers (will a transformation be required?) 2) Cubic interpolation no longer works (this is lower priority than the clipping, since vtkImageResliceMapper can be used if high-order interpolation is required) 3) The shader program for checkerboard rendering had to be removed, but it could be replaced with a new program. Perhaps, rather than replace it, it would be better to consider a solution that allows for custom fragment shaders. | ||||||||
Project | TBD | ||||||||
(0037463) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2016-03-23 19:24 | David Gobbi | New Issue | |
2016-03-23 19:24 | David Gobbi | Assigned To | => David Gobbi |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037463 | |
2016-08-12 09:55 | Kitware Robot | Status | backlog => closed |
2016-08-12 09:55 | Kitware Robot | Resolution | open => moved |
