0016025 | VTK | (No Category) | public | 2016-03-10 07:29 | 2016-08-12 09:55 | ||||
Reporter | Marc Mörig | ||||||||
Assigned To | Alvaro Sanchez | ||||||||
Summary | 0016025: Clipping appears to be inefficient in vtkGPUVolumeRayCastMapper VTK 7.0 | ||||||||
Description | When clipping planes are set, the Performance of vtkGPUVolumeRayCastMapper significantly drops, while I feel that should not be necessary. | ||||||||
Project | TBD | ||||||||
Type | performance | ||||||||
Attached Files | test_gpu_volume_mapper_performance.cc [^] (3,441 bytes) 2016-07-07 02:44 | ||||||||
(0036235) Alvaro Sanchez (developer) 2016-07-06 16:21 |
Hi Marc, thanks for reporting. Could you give me more information about your test setup (some code and data would be useful)? I tested with 6 clipping planes using a relatively small volume (Data/vase_1comp.vti) and there were no noticeable performance issues. |
(0036319) Marc Mörig (reporter) 2016-07-07 01:44 |
Dear Alvaro, thanks for investigating this. I have to check whether I can give you any data (unlikely). My datasets are 680x512x512 and for a typical transfer function, most of the volume is transparent, i.e. the ray has to travel all the way through the volume. I apply clipping planes basically in the following way (only when planes change): vtkPlanes* planes; clip_box_rep->GetPlanes(planes) mapper->RemoveAllClippingPlanes(); mapper->SetClippingPlanes(planes); My guess is, that clipping is performed per voxel or per sample and not once per ray. There is for example no performance drop if I have a transfer function that makes everything opaque. I could provide you with some test code, though I would have to create that from scratch. |
(0036320) Marc Mörig (reporter) 2016-07-07 02:48 |
I have added some code that reproduces the issue for me. |
(0036531) Alvaro Sanchez (developer) 2016-07-19 16:53 |
Thanks for the code Marc. I assume you are building the OpenGL2 backend, right? |
(0036533) Marc Mörig (reporter) 2016-07-20 01:17 |
I think so. It's the default starting with vtk 7, right? In an case my CMakeCache.txt says VTK_RENDERING_BACKEND:STRING=OpenGL2 |
(0037458) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2016-03-10 07:29 | Marc Mörig | New Issue | |
2016-07-06 10:39 | Alvaro Sanchez | Assigned To | => Alvaro Sanchez |
2016-07-06 13:27 | Alvaro Sanchez | Status | backlog => active development |
2016-07-06 16:21 | Alvaro Sanchez | Note Added: 0036235 | |
2016-07-07 01:44 | Marc Mörig | Note Added: 0036319 | |
2016-07-07 02:44 | Marc Mörig | File Added: test_gpu_volume_mapper_performance.cc | |
2016-07-07 02:48 | Marc Mörig | Note Added: 0036320 | |
2016-07-19 16:53 | Alvaro Sanchez | Note Added: 0036531 | |
2016-07-20 01:17 | Marc Mörig | Note Added: 0036533 | |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037458 | |
2016-08-12 09:55 | Kitware Robot | Status | active development => closed |
2016-08-12 09:55 | Kitware Robot | Resolution | open => moved |
