0016019 | ParaView | Bug | public | 2016-03-03 06:54 | 2016-04-18 12:52 | ||||
Reporter | Antech | ||||||||
Platform | OS | Windows-7 x64 | OS Version | 7 | |||||
Product Version | 5.0 | ||||||||
Target Version | Fixed in Version | 5.0.1 | |||||||
Summary | 0016019: ParaView 5.0 for Windows fails to open EnSight files larger than 2 GiB | ||||||||
Description | When I open EnSight (version Gold or 6) case with geometry file larger than 2 GiB in ParaView 5.0 x64 for Windows (version 7 x64) I receive a geometry file reading error: stat failed. On smaller files or under Linux (CentOS 6.7 x64) this error doesn't occour. The ParaView Windows binary installer (version 5.0.0) downloaded from official website. I took a look at the code and, possibly, found the reason for this bug. The error occures in line 114 of vtkEnSightGoldBinaryReader.cxx (stat failed). In this file stat() function and stat structure is used. For correct functionality of this syntax under 64-bit OS the macro _FILE_OFFSET_BITS should be set to 64 (otherwise 32-bit stat function and struct will be used). I didn't find _FILE_OFFSET_BITS definition in vtkEnSightGoldBinaryReader.cxx or relevant headers (I didn't check all headers cause they are related to geometry, not file operations). | ||||||||
Steps To Reproduce | 1. Open EnSight binary case with geometry file larger than 2 GiB. | ||||||||
Project | TBD | ||||||||
(0035844) Utkarsh Ayachit (administrator) 2016-03-16 11:28 |
MR: https://gitlab.kitware.com/vtk/vtk/merge_requests/1320 [^] |
(0035845) Utkarsh Ayachit (administrator) 2016-03-16 11:29 |
The fix is now merged in `master` and `5.0.1` release branch for ParaView. |
(0035895) Alan Scott (manager) 2016-04-15 22:25 |
Antech - can you test this fix? Just put a note in here if it is fixed, and I will close the bug. Thanks - Alan |
(0035898) Antech (reporter) 2016-04-18 01:42 |
Sorry, forgot about this bug report (I only posted on the mailing list). I already tested official precompiled ParaView version 5.0.1 RC2 for Windows x64 as it was introduced and there was no issue with large EnSight file (around 150 millions of cells). Thanks for debugging! |
(0035899) Alan Scott (manager) 2016-04-18 12:52 |
Tested by reporter. Closing. |
2016-03-03 06:54 | Antech | New Issue | |
2016-03-03 07:02 | Antech | Assigned To | => Utkarsh Ayachit |
2016-03-03 07:02 | Antech | Severity | minor => major |
2016-03-03 07:02 | Antech | Reproducibility | have not tried => always |
2016-03-03 07:02 | Antech | Category | (No Category) => Bug |
2016-03-03 07:02 | Antech | OS | => Windows-7 x64 |
2016-03-03 07:02 | Antech | OS Version | => 7 |
2016-03-03 07:02 | Antech | Steps to Reproduce Updated | |
2016-03-16 11:28 | Utkarsh Ayachit | Note Added: 0035844 | |
2016-03-16 11:29 | Utkarsh Ayachit | Note Added: 0035845 | |
2016-03-16 11:29 | Utkarsh Ayachit | Status | backlog => customer review |
2016-03-16 11:29 | Utkarsh Ayachit | Fixed in Version | => 5.0.1 |
2016-03-16 11:29 | Utkarsh Ayachit | Resolution | open => fixed |
2016-04-15 22:25 | Alan Scott | Note Added: 0035895 | |
2016-04-18 01:42 | Antech | Note Added: 0035898 | |
2016-04-18 12:52 | Alan Scott | Note Added: 0035899 | |
2016-04-18 12:52 | Alan Scott | Status | customer review => closed |
