0016007 | VTK | (No Category) | public | 2016-02-21 13:41 | 2016-08-12 09:55 | ||||
Reporter | Ignat Semenov | ||||||||
Summary | 0016007: VTK 7.0 fails to build on Fedora 23 | ||||||||
Description | While building VTK 7.0 downloaded as a tar.gz archive from the official VTK website, on Fedora 23, this error comes up: /home/srsly111/Software_source_packages/VTK-7.0.0/Rendering/GL2PS/vtkGL2PSContextDevice2D.cxx:23:34: fatal error: vtkOpenGLGL2PSHelper.h: No such file or directory compilation terminated. Rendering/GL2PS/CMakeFiles/vtkRenderingGL2PS.dir/build.make:72: recipe for target 'Rendering/GL2PS/CMakeFiles/vtkRenderingGL2PS.dir/vtkGL2PSContextDevice2D.cxx.o' failed make[2]: *** [Rendering/GL2PS/CMakeFiles/vtkRenderingGL2PS.dir/vtkGL2PSContextDevice2D.cxx.o] Error 1 make[2]: *** Waiting for unfinished jobs.... [ 66%] Tcl Wrapping - generating vtkQtInitializationTcl.cxx /home/srsly111/Software_source_packages/VTK-7.0.0/Rendering/GL2PS/vtkGL2PSUtilities.cxx:24:34: fatal error: vtkOpenGLGL2PSHelper.h: No such file or directory compilation terminated. Rendering/GL2PS/CMakeFiles/vtkRenderingGL2PS.dir/build.make:96: recipe for target 'Rendering/GL2PS/CMakeFiles/vtkRenderingGL2PS.dir/vtkGL2PSUtilities.cxx.o' failed make[2]: *** [Rendering/GL2PS/CMakeFiles/vtkRenderingGL2PS.dir/vtkGL2PSUtilities.cxx.o] Error 1 CMakeFiles/Makefile2:17459: recipe for target 'Rendering/GL2PS/CMakeFiles/vtkRenderingGL2PS.dir/all' failed make[1]: *** [Rendering/GL2PS/CMakeFiles/vtkRenderingGL2PS.dir/all] Error 2 make[1]: *** Waiting for unfinished jobs.... While the aforementioned file exists in the source tree: $ locate vtkOpenGLGL2PSHelper.h /home/srsly111/Software_source_packages/VTK-7.0.0/Rendering/OpenGL/vtkOpenGLGL2PSHelper.h | ||||||||
Project | Kitware | ||||||||
(0035956) Peter Mattern (reporter) 2016-05-14 19:57 |
Just tried to reproduce this. Path of VTK source code similar to the one you're using, cmake and make invoked both in-tree and outside the source tree in a dedicated directory "build" as usual, using either the system libraries or the ones included in the code. All to no avail. So are you still seeing the problem? If so how exactly do you invoke CMake and does its invocation yield some error messages? Are you trying to use the system libraries or the ones that ship with the VTK code? |
(0036222) Cory Quammen (developer) 2016-07-06 14:52 |
Please provide the non-default VTK configuration options you used when configuring with CMake. |
(0037456) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2016-02-21 13:41 | Ignat Semenov | New Issue | |
2016-05-14 19:57 | Peter Mattern | Note Added: 0035956 | |
2016-07-06 14:52 | Cory Quammen | Note Added: 0036222 | |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037456 | |
2016-08-12 09:55 | Kitware Robot | Status | backlog => closed |
2016-08-12 09:55 | Kitware Robot | Resolution | open => moved |
2016-08-12 09:55 | Kitware Robot | Assigned To | => Kitware Robot |
