0015990 | ParaView | (No Category) | public | 2016-02-11 03:40 | 2016-02-24 16:18 | ||||
Reporter | Sven Buijssen | ||||||||
Product Version | 5.0 | ||||||||
Target Version | 5.0.1 | Fixed in Version | 5.0.1 | ||||||
Summary | 0015990: Keyboard shortcut Alt+A is assigned twice: Apply button and in Color Map Editor | ||||||||
Description | Local server, Linux, master. $ paraview -dr Sources - Disk Coloring: "cellNormals", "Magnitude" menu View - tick "Color Map Editor" add any filter or source, e.g. Calculator hit Alt+A repeatedly => the focus switches between the Apply button in the properties panel and the disabled button "Render Views automatically" in the Color Map Editor. Given how often the Apply button in the properties panel is used, I vote for removal of the shortcut Alt+A for the button "Render Views automatically" in the Color Map Editor: $ sed -i -e 's/<string>Alt+A</<string></' Qt/ApplicationComponents/Resources/UI/pqColorMapEditor.ui | ||||||||
Project | TBD | ||||||||
(0035767) Utkarsh Ayachit (administrator) 2016-02-23 10:13 |
MR: https://gitlab.kitware.com/paraview/paraview/merge_requests/652 [^] |
(0035774) Alan Scott (manager) 2016-02-24 16:18 |
Tested Linux, master, local server. |
2016-02-11 03:40 | Sven Buijssen | New Issue | |
2016-02-11 03:40 | Sven Buijssen | Assigned To | => Utkarsh Ayachit |
2016-02-11 07:57 | Utkarsh Ayachit | Target Version | => 5.0.1 |
2016-02-23 10:13 | Utkarsh Ayachit | Note Added: 0035767 | |
2016-02-23 10:13 | Utkarsh Ayachit | Status | backlog => customer review |
2016-02-23 10:13 | Utkarsh Ayachit | Fixed in Version | => 5.0.1 |
2016-02-23 10:13 | Utkarsh Ayachit | Resolution | open => fixed |
2016-02-24 16:18 | Alan Scott | Note Added: 0035774 | |
2016-02-24 16:18 | Alan Scott | Status | customer review => closed |
