0015909 | VTK | (No Category) | public | 2015-12-30 04:31 | 2016-08-12 09:55 | ||||
Reporter | Pablo Hernandez-Cerdan | ||||||||
Product Version | 6.3.0 | ||||||||
Summary | 0015909: segfault in destruction of static member vtkMathInternal in vtkMath | ||||||||
Description | I reported first into the mail-list, but I thought was more suitable for a ticket: http://vtk.1045678.n5.nabble.com/vtkMath-segfault-td4917184.html#a5735703 [^] It seems a double destruction or wrong order of destruction of member pointer Gaussian of vtkMathInternal, which is static member of vtkMath http://stackoverflow.com/questions/6850009/c-deleting-static-data [^] suggests a smart pointer for Gaussian, or remove the destructor. vtk --version = 6.3 //vtkMath.h static vtkInternal Internal //vtkMath.cxx class vtkMathInternal { public: vtkMathInternal(); ~vtkMathInternal(); vtkMinimalStandardRandomSequence *Uniform; vtkBoxMuellerRandomSequence *Gaussian; std::vector<vtkTypeInt64> MemoizeFactorial; }; vtkMathInternal::vtkMathInternal() { this->Gaussian=vtkBoxMuellerRandomSequence::New(); // This line assumes the current vtkBoxMuellerRandomSequence behavior: // an initial vtkMinimalStandardRandomSequence is created. this->Uniform=static_cast<vtkMinimalStandardRandomSequence *>( this->Gaussian->GetUniformSequence()); this->Uniform->SetSeedOnly(1177); // One authors home address this->MemoizeFactorial.resize(21, 0); } vtkMathInternal::~vtkMathInternal() { this->Gaussian->Delete(); } vtkMathInternal vtkMath::Internal; ----------------------------------- Valgrind output: valgrind -v --leak-check=full ./google-test-with-fixture.run ... ==32109== Invalid free() / delete / delete[] / realloc() ==32109== at 0x4C2A144: operator delete(void*) (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so) ==32109== by 0x1D00781D: vtkMathInternal::~vtkMathInternal() (vtkMath.cxx:62) ==32109== Invalid read of size 4 ==32109== at 0x1518C4C1: vtkObjectBase::~vtkObjectBase() (in /usr/lib/libvtkCommonCore.so.1) ==32109== by 0x1518C588: vtkObjectBase::~vtkObjectBase() (in /usr/lib/libvtkCommonCore.so.1) ==32109== by 0x1D00781D: vtkMathInternal::~vtkMathInternal() (vtkMath.cxx:62) ==32109== by 0x164D32EE: __cxa_finalize (in /usr/lib/libc-2.22.so) ==32109== by 0x1CEE42A2: ??? (in /home/phc/devtoolset/release/VTK/lib/libvtkCommonCore-6.3.so.1) ==32109== Invalid read of size 4 ==32109== at 0x1518C13D: vtkObjectBase::UnRegisterInternal(vtkObjectBase*, int) (in /usr/lib/libvtkCommonCore.so.1) ==32109== by 0x1D00781D: vtkMathInternal::~vtkMathInternal() (vtkMath.cxx:62) ==32109== at 0x1518C1F0: vtkObjectBase::Delete() (in /usr/lib/libvtkCommonCore.so.1) ==32109== by 0x1D00781D: vtkMathInternal::~vtkMathInternal() (vtkMath.cxx:62) ==32109== Invalid read of size 8 ==32109== at 0x1518C090: vtkObjectBase::UnRegister(vtkObjectBase*) (in /usr/lib/libvtkCommonCore.so.1) ==32109== by 0x1D00781D: vtkMathInternal::~vtkMathInternal() (vtkMath.cxx:62) | ||||||||
Project | Release | ||||||||
Type | crash | ||||||||
Attached Files | valgrind.out [^] (94,886 bytes) 2015-12-30 04:31 | ||||||||
(0036172) Shawn Waldon (developer) 2016-07-06 10:55 |
Can you provide a simple script that can be run in valgrind to reproduce this error? My test of a common usage of vtkMath doesn't reproduce this. Since Internal is a static variable, it should be deleted at program exit which only happens once. What are you doing that is causing a double free? |
(0036318) Pablo Hernandez-Cerdan (reporter) 2016-07-06 22:55 edited on: 2016-07-06 22:56 |
I am not able to reproduce it neither! I checked git history, checkout the closest -by date- script that I used valgrind in this bug report, but no errors. I changed the computer, if that can save me from the fire. The valgrind output submitted here shows that no google test was running, but the memory leak exists anyway?. Maybe it was related with some google fixture... sorry, I will attach a simple script next time :( |
(0037442) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2015-12-30 04:31 | Pablo Hernandez-Cerdan | New Issue | |
2015-12-30 04:31 | Pablo Hernandez-Cerdan | File Added: valgrind.out | |
2016-07-06 10:26 | Shawn Waldon | Assigned To | => Shawn Waldon |
2016-07-06 10:55 | Shawn Waldon | Note Added: 0036172 | |
2016-07-06 10:56 | Shawn Waldon | Assigned To | Shawn Waldon => |
2016-07-06 22:55 | Pablo Hernandez-Cerdan | Note Added: 0036318 | |
2016-07-06 22:56 | Pablo Hernandez-Cerdan | Note Edited: 0036318 | |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037442 | |
2016-08-12 09:55 | Kitware Robot | Status | backlog => closed |
2016-08-12 09:55 | Kitware Robot | Resolution | open => moved |
2016-08-12 09:55 | Kitware Robot | Assigned To | => Kitware Robot |
