0015883 | VTK | (No Category) | public | 2015-12-16 07:34 | 2016-08-12 09:55 | ||||
Reporter | Liu Huiwei | ||||||||
Product Version | 6.3.0 | ||||||||
Summary | 0015883: vtkOpenGLIndexBufferObject in OpenGL2 Bug | ||||||||
Description | When you use an existing Mapper,just change input data ,for example,polydata with lines changes to only with vertexs,render cause crash,the code blew size_t vtkOpenGLIndexBufferObject::CreatePointIndexBuffer(vtkCellArray *cells) { if (!cells->GetNumberOfCells()) { //add this line //no line data,but IndexCount!=0 this->IndexCount = 0; return 0; } std::vector<unsigned int> indexArray; AppendPointIndexBuffer(indexArray, cells, 0); this->Upload(indexArray, vtkOpenGLIndexBufferObject::ElementArrayBuffer); this->IndexCount = indexArray.size(); return indexArray.size(); } | ||||||||
Project | TBD | ||||||||
(0036234) Dan Lipsa (developer) 2016-07-06 16:21 |
Liu, can you add a test data and a small test that shows the problem? Loading a poly data that consists only of points in ParaView 5.1 works fine. |
(0037438) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2015-12-16 07:34 | Liu Huiwei | New Issue | |
2016-07-06 16:21 | Dan Lipsa | Note Added: 0036234 | |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037438 | |
2016-08-12 09:55 | Kitware Robot | Status | backlog => closed |
2016-08-12 09:55 | Kitware Robot | Resolution | open => moved |
2016-08-12 09:55 | Kitware Robot | Assigned To | => Kitware Robot |
