0015867 | ParaView | (No Category) | public | 2015-12-07 09:38 | 2016-01-08 15:32 | ||||
Reporter | Cory Quammen | ||||||||
Assigned To | Cory Quammen | ||||||||
Product Version | 5.0 | ||||||||
Target Version | 5.0 | Fixed in Version | 5.0 | ||||||
Summary | 0015867: Camera parallel projection setting not loaded from defaults | ||||||||
Description | Bug report from Kenichiro Yoshimi: I am using 5.0.0-RC1 64-bit on Windows. I save the parallel projection setting as default: - Toggle the advanced properties. - Open view (Render view). - Check "Camera Parallel Projection". - Click on the save button shows "Save current view settings values as default". After reopening ParaView, the check box of "Camera Parallel Projection" is checked, but new view is not parallel. I think it is a bug that needs to be fixed in 5.0.0. | ||||||||
Project | Sandia | ||||||||
(0035518) Cory Quammen (developer) 2015-12-07 09:39 |
The problem is that parallel projection is a setting that has the ignore synchronization flag set. This prevents the defaults, which are correctly loaded by the server manager, from making it to the client-side object. |
(0035527) Utkarsh Ayachit (administrator) 2015-12-09 11:38 |
https://gitlab.kitware.com/paraview/paraview/merge_requests/509 [^] |
(0035577) Alan Scott (manager) 2015-12-16 16:39 |
Tested Linux, 5.0.0-RC2, remote server. Expected behavior is to never have the Camera Parallel Projection be sticky. However, you can save the View state with the save button. Tested that, works fine. |
2015-12-07 09:38 | Cory Quammen | New Issue | |
2015-12-07 09:38 | Cory Quammen | Assigned To | => Cory Quammen |
2015-12-07 09:39 | Cory Quammen | Note Added: 0035518 | |
2015-12-07 09:39 | Cory Quammen | Status | backlog => active development |
2015-12-09 11:38 | Utkarsh Ayachit | Note Added: 0035527 | |
2015-12-09 11:38 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2015-12-09 11:38 | Utkarsh Ayachit | Resolution | open => fixed |
2015-12-09 11:38 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-12-09 11:38 | Utkarsh Ayachit | Fixed in Version | => git-master |
2015-12-16 16:39 | Alan Scott | Note Added: 0035577 | |
2015-12-16 16:39 | Alan Scott | Status | customer review => closed |
2016-01-08 15:31 | Utkarsh Ayachit | Target Version | => 5.0 |
2016-01-08 15:32 | Utkarsh Ayachit | Fixed in Version | git-master => 5.0 |
