0015835 | VTK | (No Category) | public | 2015-11-13 09:48 | 2016-08-12 09:55 | ||||
Reporter | Luc Habert | ||||||||
Assigned To | Sujin Philip | ||||||||
Summary | 0015835: vtkImplicitPlaneWidget2: tubing error | ||||||||
Description | When the plane is incident to one of the vertices of the box, the cutter produces two points for this vertex, leading to an error during the tubing: Generic Warning: In F:\lhabert\dev\VTK-6.3.0\Common\DataModel\vtkPolyLine.cxx, line 106 Coincident points in polyline...can't compute normals Warning: In F:\lhabert\dev\VTK-6.3.0\Filters\Core\vtkTubeFilter.cxx, line 243 vtkTubeFilter (0000000020976ED0): Could not generate normals for line. Skipping to next. | ||||||||
Project | TBD | ||||||||
(0035449) Luc Habert (reporter) 2015-11-13 09:49 edited on: 2015-11-13 10:22 |
Here is a sample code that triggers the error: vtkNew<vtkRenderWindow> window; vtkNew<vtkRenderer> renderer; window->AddRenderer(renderer.GetPointer()); vtkNew<vtkRenderWindowInteractor> iren; iren->SetRenderWindow(window.GetPointer()); window->SetSize(600, 600); iren->Initialize(); vtkNew<vtkImplicitPlaneWidget2> wid; vtkImplicitPlaneRepresentation *rep = static_cast<vtkImplicitPlaneRepresentation*>(wid->GetRepresentation()); wid->SetInteractor(iren.GetPointer()); wid->EnabledOn(); double box[6] = { -54675.000000000000, -54675.000000000000 + 328050.00000000000, -54675.000000000000, -54675.000000000000 + 328050.00000000000, -14234.213333129883 + 20845.697479248047 }; rep->PlaceWidget(box); rep->SetNormal(-0.46107891854792293, 0.29238370636160577, -0.83780546615842055); rep->SetOrigin(273374.99999988079, 273374.99999988079, -14234.212890505791); renderer->ResetCamera(); iren->Start(); |
(0035455) Luc Habert (reporter) 2015-11-17 06:49 |
inserting a vtkCleanPolyData between Edges and EdgesTuber fixes this issue |
(0035458) Joachim Pouderoux (developer) 2015-11-18 05:36 edited on: 2015-11-18 05:36 |
Please refer to https://gitlab.kitware.com/vtk/vtk/blob/master/CONTRIBUTING.md [^] if you wish to propose a patch for this issue. |
(0037434) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2015-11-13 09:48 | Luc Habert | New Issue | |
2015-11-13 09:49 | Luc Habert | Note Added: 0035449 | |
2015-11-13 10:22 | Luc Habert | Note Edited: 0035449 | |
2015-11-17 06:49 | Luc Habert | Note Added: 0035455 | |
2015-11-18 05:36 | Joachim Pouderoux | Note Added: 0035458 | |
2015-11-18 05:36 | Joachim Pouderoux | Note Edited: 0035458 | |
2016-07-06 10:19 | Sujin Philip | Assigned To | => Sujin Philip |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037434 | |
2016-08-12 09:55 | Kitware Robot | Status | backlog => closed |
2016-08-12 09:55 | Kitware Robot | Resolution | open => moved |
