0015797 | VTK | (No Category) | public | 2015-10-21 11:58 | 2016-05-13 17:06 | ||||
Reporter | Cory Quammen | ||||||||
Assigned To | Cory Quammen | ||||||||
Product Version | 6.3.0 | ||||||||
Target Version | Fixed in Version | 7.1.0 | |||||||
Summary | 0015797: Text caching mechanism in vtkOpenGLContextDevice2DPrivate fails if just shadow property changes | ||||||||
Description | Enabling/disabling text shadow in a vtkTextProperty fails to invalidate cache entries in the vtkTextureImageCache. The problem is that the shadow property state is not included as part of the hashing for vtkTextProperty instances. | ||||||||
Project | Sandia | ||||||||
(0035954) Cory Quammen (developer) 2016-05-13 17:06 |
Fixed in commit commit 1d91f9bad3f7d325a7a28b1441afe5f311252fb8 Author: Cory Quammen <cory.quammen@kitware.com> Date: Wed Oct 21 13:14:50 2015 -0400 BUG 15797: Fix text property ID computation Only a few settings defined by the vtkTextProperty were used to compute the text property ID in MapTextPropertyToId(). This can cause incorrect rendering when settings that weren't considered, such as the shadow setting, were changed. Added a more general hashing function, HashBuffer(), to accommodate all the vtkTextProperty settings, and use this to compute the vtkTextProperty hash. HashString() is no longer used, but remains for backwards compatibility. Added a test to ensure that changing a setting results in the computation of a different ID. |
2015-10-21 11:58 | Cory Quammen | New Issue | |
2015-10-21 11:58 | Cory Quammen | Assigned To | => Cory Quammen |
2016-05-13 17:06 | Cory Quammen | Note Added: 0035954 | |
2016-05-13 17:06 | Cory Quammen | Status | backlog => closed |
2016-05-13 17:06 | Cory Quammen | Resolution | open => fixed |
2016-05-13 17:06 | Cory Quammen | Fixed in Version | => 7.1.0 |
