0015795 | VTK | (No Category) | public | 2015-10-21 10:43 | 2016-07-06 14:06 | ||||
Reporter | Dženan Zukić | ||||||||
Assigned To | Shawn Waldon | ||||||||
Target Version | Fixed in Version | 7.1.0 | |||||||
Summary | 0015795: Two rendering tests fail on VS2013 and VS2015 | ||||||||
Description | vtkRenderingCoreCxx-TestResetCameraVerticalAspectRatio and vtkRenderingCoreCxx-TestResetCameraVerticalAspectRatioParallel fail on Visual Studio 2013 and 2015. The log for following command is attached: C:\Dev\vtk-my-2013>ctest -C Release -R vtkRenderingCoreCxx-TestResetCameraVerticalAspectRatio -V After examining the execution log, Cory suspects that the menu bar is shown (and it shouldn't be). | ||||||||
Tags | hackaton | ||||||||
Project | TBD | ||||||||
Attached Files | vtkCTest.log [^] (3,840 bytes) 2015-10-21 10:43 | ||||||||
(0035322) Ben Boeckel (Kitware) (developer) 2015-10-21 11:17 |
These tests are passing on our VS2013 and VS2015 dashboards. See these builds: 2013: https://buildbot.kitware.com/builders/vtk-nemesis-windows-shared-release%2Bmpi%2Bopengl2%2Bpython/builds/1785 [^] 2015: https://buildbot.kitware.com/builders/vtk-nemesis-windows-shared-release%2Bmpi%2Bmsvc2015%2Bopengl2%2Bpython/builds/716 [^] |
(0035326) Dženan Zukić (developer) 2015-10-21 11:28 edited on: 2015-10-21 11:29 |
Maybe CMake configuration setting matter? Settings different from defaults are: VTK_Group_Imaging ON VTK_Group_Qt ON VTK_LEGACY_REMOVE ON VTK_SMP_IMPLEMENTATION_TYPE OpenMP Qt version used is 4.8.7 Build is x64 |
(0035352) Ben Boeckel (Kitware) (developer) 2015-10-21 13:37 |
The OpenMP backend is probably the cause. Does it work if you use Sequential? |
(0035371) Dženan Zukić (developer) 2015-10-21 16:06 |
It fails even after I changed to Sequential. |
(0036215) Shawn Waldon (developer) 2016-07-06 14:06 |
I just checked CDash, this is fixed in the latest master builds. The tests mentioned have been passing for a while. I'm just putting the fixed in version as master... I don't feel like bisecting on Windows. |
2015-10-21 10:43 | Dženan Zukić | New Issue | |
2015-10-21 10:43 | Dženan Zukić | File Added: vtkCTest.log | |
2015-10-21 11:17 | Ben Boeckel (Kitware) | Note Added: 0035322 | |
2015-10-21 11:28 | Dženan Zukić | Note Added: 0035326 | |
2015-10-21 11:29 | Dženan Zukić | Note Edited: 0035326 | |
2015-10-21 13:37 | Ben Boeckel (Kitware) | Note Added: 0035352 | |
2015-10-21 15:51 | Ben Boeckel (Kitware) | Tag Attached: hackaton | |
2015-10-21 16:06 | Dženan Zukić | Note Added: 0035371 | |
2016-07-06 14:06 | Shawn Waldon | Note Added: 0036215 | |
2016-07-06 14:06 | Shawn Waldon | Status | backlog => closed |
2016-07-06 14:06 | Shawn Waldon | Assigned To | => Shawn Waldon |
2016-07-06 14:06 | Shawn Waldon | Resolution | open => fixed |
2016-07-06 14:06 | Shawn Waldon | Fixed in Version | => 7.1.0 |
