0015769 | ParaView | Bug | public | 2015-10-10 06:05 | 2016-08-24 08:25 | ||||
Reporter | Cédric Robert | ||||||||
Platform | OS | Windows | OS Version | 10 | |||||
Product Version | 4.4 | ||||||||
Summary | 0015769: BlankPoint: Blanking turns off too much points in the structured grid | ||||||||
Description | Too much points are turned off when using blankPoint method. | ||||||||
Steps To Reproduce | Looking at the example available at : http://www.vtk.org/Wiki/VTK/Examples/Cxx/StructuredGrid/BlankPoint [^] If we change the pointId in function BlankPoint from 27 to 1, then the points ID 0, 1 and cells Id 0, 1 are turned off. The behaviour of point ID 1 is fine, the behaviour of cells Id 0 and 1 is fine as well. But the behaviour the point ID 0 is wrong. Indeed, we never asked the point ID 0 to be turned off. | ||||||||
Project | TBD | ||||||||
(0035293) Joachim Pouderoux (developer) 2015-10-15 08:52 |
This is a VTK related issue, not a ParaView one. Please report it on the VTK bug tracker (http://www.vtk.org/Bug/view_all_bug_page.php [^] , on the top-right combo box, choose VTK project instead of ParaView). Thanks. |
(0035294) Joachim Pouderoux (developer) 2015-10-15 09:03 |
By the way the behaviour seems OK for me: if you turn OFF the point 1, it affects the visibility of the connected cells (0 and 1). As point 0 is only connected to cell 0, it will not be visible when drawing mesh cells as the cell 0 is blanked... but it does not mean the point 0 is blanked. |
(0035295) Cédric Robert (reporter) 2015-10-15 09:37 |
Yes I understand your explanation. But in ParaView, if we change the representation in representation type combo-box from "surface" to "points", then the point 0 is not visible. |
(0035296) Joachim Pouderoux (developer) 2015-10-15 09:39 |
You are right, but it does not mean the point 0 is blanked either :) The "points" representation display points of the geometry mesh cells (instead of the cells themselves). As the point 0 is not refered by any cell, it is not displayed. |
(0035297) Cédric Robert (reporter) 2015-10-15 10:39 |
How would you show all the points of a 2d structured mesh minus a defined (tiny) subset of them? Since my points are regularly spaced, I am not thinking about using a pure cloud of points. In the example we discuss, how would you show ALL points except point ID 1? I am trying to achieve that using blankPoint method but I may use the wrong approach and consequently wrongly assume I am facing a bug. |
(0035298) Joachim Pouderoux (developer) 2015-10-15 10:58 |
In ParaView you could use the Find Data dialog, find points "ID is 1", then check the "Invert selection" check box. It will select all points but the one with ID=1. You can then extract the selection and will obtain a point cloud without the selected point. |
(0038905) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-10-10 06:05 | Cédric Robert | New Issue | |
2015-10-14 05:46 | Cédric Robert | Category | (No Category) => Bug |
2015-10-14 05:46 | Cédric Robert | OS | => Windows |
2015-10-14 05:46 | Cédric Robert | OS Version | => 10 |
2015-10-14 05:46 | Cédric Robert | Description Updated | |
2015-10-14 05:46 | Cédric Robert | Steps to Reproduce Updated | |
2015-10-15 08:52 | Joachim Pouderoux | Note Added: 0035293 | |
2015-10-15 09:03 | Joachim Pouderoux | Note Added: 0035294 | |
2015-10-15 09:37 | Cédric Robert | Note Added: 0035295 | |
2015-10-15 09:39 | Joachim Pouderoux | Note Added: 0035296 | |
2015-10-15 10:39 | Cédric Robert | Note Added: 0035297 | |
2015-10-15 10:58 | Joachim Pouderoux | Note Added: 0035298 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038905 | |
2016-08-24 08:25 | Kitware Robot | View Status | private => public |
