0015762ParaView(No Category)public2015-10-08 16:362016-02-24 15:24
ReporterAlan Scott
Assigned ToAlan Scott
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version4.4
Target Version5.0.1Fixed in Version5.0
Summary0015762: Trace fails setting variables on Mac
DescriptionThis bug appears to be Mac/ OS X only.
* Mac OS X, 4.4.0, local server.
* Start trace. Fully Trace Suplemental Proxies on. OK.
* Sources/ Wavelet. Apply.
* Change Outline to Surface, Change Solid Color to RTData.
* Color Editor. Preset. Rainbow Desaturated.
* Stop trace. Save as Macro (or as just Python file).
* Edit/ Reset Session.
* Run the macro.
<<Bug>> - Wavelet won't even appear! Change visibility to off, then back on in the pipeline browser.
<<Bug>> - At this point, the wavelet appears solid color. Not painted by variable.
>> This needs to be fixed for 5.0.
>> If possible, I need a fix - in python - that the user can cut and paste into his scripts.
TagsNo tags attached.
ProjectSandia
Topic Name
Typeincorrect functionality
Attached Files? file icon generated_trace.py [^] (2,217 bytes) 2016-02-23 23:01
png file icon Screen Shot 2016-02-23 at 11.01.08 PM.png [^] (342,520 bytes) 2016-02-23 23:01
 Relationships
  Notes
(0035770)
2016-02-23 23:00
edited on: 2016-02-23 23:01
Alan,
I cannot reproduce this with the latest release revision v5.0.0-39-g620a6d1 even on a Mac.
I am attaching the Python trace that was generated in my case. Playing it back shows exactly what I traced out and the image I get after playing back the trace.
 Can you attach the Python file you are getting?
(0035771)
Alan Scott (manager)
2016-02-24 15:24
Utkarsh is correct - this was fixed in 5.0. I tested on 5.0.0, it works fine.
Tested on Mac, Kitware 5.0.0 .dmg, local server.
 Issue History
2015-10-08 16:36 Alan Scott New Issue
2015-10-08 16:37 Alan Scott Target Version => 5.0
2016-01-08 15:31 Utkarsh Ayachit Target Version 5.0 => 5.1
2016-02-04 19:46 Alan Scott Target Version 5.1 => 5.0.1
2016-02-23 23:00 Utkarsh Ayachit Note Added: 0035770
2016-02-23 23:01 Utkarsh Ayachit File Added: generated_trace.py
2016-02-23 23:01 Utkarsh Ayachit File Added: Screen Shot 2016-02-23 at 11.01.08 PM.png
2016-02-23 23:01 Utkarsh Ayachit Note Edited: 0035770
2016-02-24 15:24 Alan Scott Note Added: 0035771
2016-02-24 15:24 Alan Scott Status backlog => closed
2016-02-24 15:24 Alan Scott Assigned To => Alan Scott
2016-02-24 15:24 Alan Scott Resolution open => fixed
2016-02-24 15:24 Alan Scott Fixed in Version => 5.0
