0015724 | ParaView | (No Category) | public | 2015-09-14 11:48 | 2016-08-12 09:59 | ||||
Reporter | Joachim Pouderoux | ||||||||
Product Version | 4.4 | ||||||||
Summary | 0015724: Changing palette does not work if one change the background manually | ||||||||
Description | When saving a screenshot or using the palette button to change the background, the background color is not changed if you have changed the view background manually before. Even clicking "Restore Default" background button do not fix the problem. | ||||||||
Steps To Reproduce | Start ParaView 4.4 1 - Create a wavelet source. 2 - Change the background color to red (or whatever) in the (View) Properties panel 3 - File/Save Screenshot: choose to override palette with White palette and save. The generated screenshot still has the red background. 4- Click on "Restore Default" in the (View) Properties panel. Background is restored to default. 5 - repeat step 3 again. The generated screenshot has a gray (default) background, not a white one. | ||||||||
Project | TBD | ||||||||
(0038893) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-09-14 11:48 | Joachim Pouderoux | New Issue | |
2015-09-14 11:51 | Joachim Pouderoux | Steps to Reproduce Updated | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038893 | |
