0015704 | ParaView | (No Category) | public | 2015-09-07 03:46 | 2015-12-15 20:23 | ||||
Reporter | mag | ||||||||
Assigned To | Dan Lipsa | ||||||||
Target Version | Fixed in Version | 5.0 | |||||||
Summary | 0015704: segmentation fault when loading cgns file | ||||||||
Description | I used the Release Candidate 2 of 4.4 Linux-64bit on Ubuntu 14.10. Paraview starts and behaves normally. Then, when I try to load a cgns file paraview crashes saying "segementation fault". I had this problem also in former version of the new CGNS plugin. | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
Attached Files | vtkCGNSReader.cxx.diff [^] (1,850 bytes) 2015-10-13 04:48 [Show Content] | ||||||||
(0035216) mag (reporter) 2015-09-15 06:45 |
I found a workaround. The problems seems to be linked to the "CGNSLibraryVersion" node. When I change it from "3.21" to "2.54" it works. |
(0035277) Jim Eliot (reporter) 2015-10-13 04:49 |
I also ran into this issue with the ParaView CGNS reader and I did some investigating. The problem occurred for me when moving from ParaView 4.3.1 to ParaView 4.4.0 due to the disabling of the VisIt CGNS reader. Files fail to open in the CGNS reader which have a version number that is higher than the CGNS library version (3.1). The cause is some incorrect version checks in the CGNS reader. For non-hdf5-based files, the file does not open. For hdf5-based files, the file does not open and then a segmentation fault occurs in the CanReadFile of vtkMPASReader. It looks like this is due to a strcpy on a null pointer. I fixed the incorrect behavior in the CGNS reader which means that the file opens and therefore vtkMPASReader::CanReadFile is not reached and the segfault doesn't occur. I have attached a file called vtkCGNSReader.cxx.diff which contains a git diff for the changes that I made to vtkCGNSReader.cxx. |
(0035377) Jim Eliot (reporter) 2015-10-22 08:59 |
An example file that will trigger the failure can be found on the main CGNS webpage. The url of the file is: http://cgns.github.io/CGNSFiles/Chris/bump_hdf5.cgns.gz [^] |
(0035378) Dan Lipsa (developer) 2015-10-22 11:56 |
Thanks Jim for reporting the error and contributing the fix. Here are the merge requests: https://gitlab.kitware.com/vtk/vtk/merge_requests/809 [^] https://gitlab.kitware.com/paraview/paraview/merge_requests/445 [^] |
(0035567) Alan Scott (manager) 2015-12-15 20:23 |
Closing untested. If there still is an issue, please reopen the bug. Alan |
2015-09-07 03:46 | mag | New Issue | |
2015-09-07 03:46 | mag | Assigned To | => Alan Scott |
2015-09-08 15:46 | Alan Scott | Assigned To | Alan Scott => |
2015-09-15 06:45 | mag | Note Added: 0035216 | |
2015-10-13 04:48 | Jim Eliot | File Added: vtkCGNSReader.cxx.diff | |
2015-10-13 04:49 | Jim Eliot | Note Added: 0035277 | |
2015-10-13 13:22 | Alan Scott | Project | Sandia => TBD |
2015-10-21 15:38 | Dan Lipsa | Assigned To | => Dan Lipsa |
2015-10-21 15:38 | Dan Lipsa | Status | backlog => active development |
2015-10-22 08:59 | Jim Eliot | Note Added: 0035377 | |
2015-10-22 11:56 | Dan Lipsa | Note Added: 0035378 | |
2015-11-04 13:53 | Dan Lipsa | Status | active development => gatekeeper review |
2015-12-11 14:58 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-12-11 14:58 | Utkarsh Ayachit | Resolution | open => fixed |
2015-12-11 14:58 | Utkarsh Ayachit | Fixed in Version | => 5.0 |
2015-12-15 20:23 | Alan Scott | Note Added: 0035567 | |
2015-12-15 20:23 | Alan Scott | Status | customer review => closed |
