0015702 | ParaView | (No Category) | public | 2015-09-04 15:37 | 2016-01-08 15:32 | ||||
Reporter | Andy Bauer | ||||||||
Target Version | 5.0 | Fixed in Version | 5.0 | ||||||
Summary | 0015702: allow gradient of unstructured data to optionally skip outputting the gradient but allow other gradient quantities to be output | ||||||||
Description | Change the vtkGradientFilter to change the way gradients are computed for structured grids such that no gradient array is created (i.e. the array with 3 times the components if the input array and same number of points). often times other gradient quantities like vorticity or Q criterion are desired instead and the full gradient array can take up a lot of memory. for unstructured grids and polydata it probably won't make much of a difference memory-wise since cell links are used and the full gradient array is calculated at the beginning in order make a one-pass algorithm for computing gradients. this shouldn't be needed for image data, rectilinear grids and structured grids. this option should also be exposed in PV. | ||||||||
Project | ERDC | ||||||||
Type | feature | ||||||||
Relationships | ||||||
There are no notes attached to this issue. |
2015-09-04 15:37 | Andy Bauer | New Issue | |
2015-09-04 15:37 | Andy Bauer | Assigned To | => Utkarsh Ayachit |
2015-09-04 15:38 | Andy Bauer | Relationship added | related to 0015471 |
2015-12-09 10:47 | Andy Bauer | Status | backlog => gatekeeper review |
2015-12-09 10:47 | Andy Bauer | Fixed in Version | => git-master |
2015-12-09 10:47 | Andy Bauer | Resolution | open => fixed |
2015-12-09 10:47 | Andy Bauer | Status | gatekeeper review => closed |
2016-01-08 15:31 | Utkarsh Ayachit | Target Version | => 5.0 |
2016-01-08 15:32 | Utkarsh Ayachit | Fixed in Version | git-master => 5.0 |
