0015691 | ParaView | (No Category) | public | 2015-08-27 11:53 | 2015-09-06 12:17 | ||||
Reporter | Mathieu Westphal | ||||||||
Assigned To | Mathieu Westphal | ||||||||
Target Version | Fixed in Version | 4.4 | |||||||
Summary | 0015691: Add a combo box in line widget to choose which point to pick | ||||||||
Description | Add a combo box in line widget to choose which point to pick, so point picking can be use as a precise tool to position points. | ||||||||
Project | TBD | ||||||||
Type | feature | ||||||||
(0035085) Mathieu Westphal (developer) 2015-08-27 11:54 |
fixed by:https://gitlab.kitware.com/paraview/paraview/merge_requests/332 [^] |
(0035104) Utkarsh Ayachit (administrator) 2015-08-31 14:42 |
merged |
(0035139) Alan Scott (manager) 2015-09-02 17:34 |
From Mathieu: When a line widget is visible in paraview ( for example Plot Over Line filter ), one can press the "P" key to pick a one of the point of the line on the surface of the mesh. However, the pqLineWidget will pick point1, then at next press to "P" key it will pick Point2, and again Point1 and again Point2 ... So when you misplace pick a point, you must repick the other point before picking again the first point. this feature allow to choose which point to pick, so you can repick it easilly. You can even let the "P" key down to track the mouse position on the surface of the mesh, and therefore by very precise where you pick the point |
(0035140) Alan Scott (manager) 2015-09-02 17:37 |
Tested master, Linux, remote server. |
2015-08-27 11:53 | Mathieu Westphal | New Issue | |
2015-08-27 11:53 | Mathieu Westphal | Assigned To | => Mathieu Westphal |
2015-08-27 11:54 | Mathieu Westphal | Note Added: 0035085 | |
2015-08-27 11:54 | Mathieu Westphal | Status | backlog => gatekeeper review |
2015-08-27 11:54 | Mathieu Westphal | Resolution | open => fixed |
2015-08-31 14:42 | Utkarsh Ayachit | Note Added: 0035104 | |
2015-08-31 14:42 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-08-31 14:42 | Utkarsh Ayachit | Fixed in Version | => git-master |
2015-09-02 17:34 | Alan Scott | Note Added: 0035139 | |
2015-09-02 17:37 | Alan Scott | Note Added: 0035140 | |
2015-09-02 17:37 | Alan Scott | Status | customer review => closed |
2015-09-06 12:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
