0015673 | ParaView | (No Category) | public | 2015-08-24 09:49 | 2015-09-09 21:56 | ||||
Reporter | Christophe Bourcier | ||||||||
Assigned To | Cory Quammen | ||||||||
Product Version | 4.3 | ||||||||
Target Version | 4.4 | Fixed in Version | 4.4 | ||||||
Summary | 0015673: The scalar bar range does not match the range in the the information panel | ||||||||
Description | 1) Load agitateur.vtm (archive is attached). 2) Go to the last time step 3) Display PRESSION_ELEM_DOM field. 4) Click the icon to Rescale data range. => The scalar bar indicates min -4.886 and max 321.3 5) Go to the Information panel. The line PRESSION_ELEM_DOM indicates for the time step values : -10.241 and 532.444. The values from the Information panel are correct. Those of the scalar bar are false. Reproduced on v4.4.0-RC1. | ||||||||
Project | Sandia | ||||||||
Attached Files | agitateur.tgz [^] (945,656 bytes) 2015-08-24 09:49 | ||||||||
(0035041) Christophe Bourcier (reporter) 2015-08-24 10:27 |
Moving the GetArrayInformation call a few lines below solves the problem. See the merge request: https://gitlab.kitware.com/paraview/paraview/merge_requests/321 [^] |
(0035043) Alan Scott (manager) 2015-08-24 13:01 |
Targeting for this release. Misrepresents data, and reporter has supplied a fix. Thanks for reporting! |
(0035194) Alan Scott (manager) 2015-09-09 21:56 |
Tested master, Linux, local server. |
2015-08-24 09:49 | Christophe Bourcier | New Issue | |
2015-08-24 09:49 | Christophe Bourcier | File Added: agitateur.tgz | |
2015-08-24 10:27 | Christophe Bourcier | Note Added: 0035041 | |
2015-08-24 13:01 | Alan Scott | Project | ParaViS => Sandia |
2015-08-24 13:01 | Alan Scott | Note Added: 0035043 | |
2015-08-24 13:01 | Alan Scott | Status | backlog => todo |
2015-08-24 13:01 | Alan Scott | Target Version | => 4.4 |
2015-08-30 23:40 | Cory Quammen | Assigned To | => Cory Quammen |
2015-08-30 23:40 | Cory Quammen | Status | todo => active development |
2015-09-03 09:32 | Utkarsh Ayachit | Status | active development => customer review |
2015-09-03 09:32 | Utkarsh Ayachit | Fixed in Version | => git-master |
2015-09-03 09:32 | Utkarsh Ayachit | Resolution | open => fixed |
2015-09-06 12:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
2015-09-09 21:56 | Alan Scott | Note Added: 0035194 | |
2015-09-09 21:56 | Alan Scott | Status | customer review => closed |
