0015550 | ParaView | (No Category) | public | 2015-06-17 17:15 | 2015-09-06 12:17 | ||||
Target Version | 4.4 | Fixed in Version | 4.4 | ||||||
Summary | 0015550: Interactive selection cursor weirdnesses | ||||||||
Description | There are weirdness-es for interactive selection. This has to do with the place ParaView thinks the cursor is located. * Linux, master, local server. * Sources/ Wavelet. Apply. Surface. * Interactive Select Cells On. >> Now, move the mouse around on the cube. Notice that the highlighted cell is under the mouse. * Split window horizontally. Spreadsheet. * Now, move the cursor back onto the wavelet square. Notice that the selected cell is no longer under the mouse. This is a bug. As per Utkarsh, the correct fix is to turn off the Interactive Selection when the mouse is used outside of the 3d window. I would argue that this should be true of any selections. | ||||||||
Project | Sandia | ||||||||
(0034646) Utkarsh Ayachit (administrator) 2015-07-02 10:51 |
Correction: My comment was to potentially turn off selection when views are resized or split, not when mouse moves out the window :). |
(0034649) Utkarsh Ayachit (administrator) 2015-07-02 11:09 |
commit f33ffef925b2b8568f8607b54545f4347af7c4d9 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Jul 2 11:07:54 2015 -0400 BUG 0015550: Invalidate selection cache on resize. Interactive selection uses caching of the selection color buffers to avoid having to render the selection passes for every mouse interaction. That means that if the window was resized, we needed to explicitly clear the cache for it to work. This change does the same. |
(0034650) Utkarsh Ayachit (administrator) 2015-07-02 11:10 |
I opted to clear the internal cache instead of getting out of selection mode as it seemed more intuitive and easier to implement. |
(0034651) Utkarsh Ayachit (administrator) 2015-07-02 11:12 |
Merge request: https://gitlab.kitware.com/paraview/paraview/merge_requests/189 [^] |
(0034656) Utkarsh Ayachit (administrator) 2015-07-03 10:14 |
Merged in master. |
(0034756) Alan Scott (manager) 2015-07-10 21:18 |
Oh, this functionality is so very perfect. Wonderful job to Utkarsh and Kitware. Tested remote server, Linux, master. |
2015-06-17 17:15 | Alan Scott | New Issue | |
2015-06-17 17:15 | Alan Scott | Target Version | => 4.4 |
2015-07-02 10:51 | Utkarsh Ayachit | Note Added: 0034646 | |
2015-07-02 11:09 | Utkarsh Ayachit | Note Added: 0034649 | |
2015-07-02 11:09 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2015-07-02 11:09 | Utkarsh Ayachit | Resolution | open => fixed |
2015-07-02 11:09 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2015-07-02 11:10 | Utkarsh Ayachit | Note Added: 0034650 | |
2015-07-02 11:12 | Utkarsh Ayachit | Note Added: 0034651 | |
2015-07-03 10:14 | Utkarsh Ayachit | Note Added: 0034656 | |
2015-07-03 10:14 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-07-03 10:14 | Utkarsh Ayachit | Fixed in Version | => git-master |
2015-07-10 21:18 | Alan Scott | Note Added: 0034756 | |
2015-07-10 21:18 | Alan Scott | Status | customer review => closed |
2015-09-06 12:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
