0015533 | VTK | (No Category) | public | 2015-06-11 12:45 | 2015-08-07 08:20 | ||||
Reporter | Cory Quammen | ||||||||
Assigned To | T.J. Corona | ||||||||
Product Version | 6.3.0 | ||||||||
Target Version | Fixed in Version | 6.3.0 | |||||||
Summary | 0015533: vtkAbstractArray::Reset() does not really reset arrays | ||||||||
Description | The Reset() method does not reset all array state. For instance, in vtkVariantArray, the lookup structure is not reset. This leads to unexpected behavior. This example shows the problem. vtkVariantArray* array = vtkVariantArray::New() array->SetNumberOfTuples(5); array->InsertNextTuple(value); ... vtkIdType idx = array->LookupValue(value); // idx is > -1 array->Reset(); idx = array->LookupValue(value); // idx should be -1, but is larger than -1 Reset() should be made virtual to give subclasses a chance to override and reset any additional state they define. A pass through VTK data arrays should be made to verify that all state is reset when Reset() is called. | ||||||||
Project | TBD | ||||||||
(0034915) T.J. Corona (developer) 2015-08-06 18:28 |
This issue has been fixed. |
(0034919) Cory Quammen (developer) 2015-08-06 22:22 |
T.J. Could you copy and paste the git log entry for the commit that fixes the issue here? Thanks, Cory |
(0034922) T.J. Corona (developer) 2015-08-07 08:20 |
Hi Cory, The commit message can be found here: https://gitlab.kitware.com/vtk/vtk/commit/ac031ed42a939f8f79f827def05a96995068cb62 [^] -T.J. |
2015-06-11 12:45 | Cory Quammen | New Issue | |
2015-08-05 10:21 | Utkarsh Ayachit | Assigned To | => T.J. Corona |
2015-08-06 18:28 | T.J. Corona | Note Added: 0034915 | |
2015-08-06 18:28 | T.J. Corona | Status | backlog => closed |
2015-08-06 18:28 | T.J. Corona | Resolution | open => fixed |
2015-08-06 18:28 | T.J. Corona | Fixed in Version | => 6.3.0 |
2015-08-06 22:22 | Cory Quammen | Note Added: 0034919 | |
2015-08-07 08:20 | T.J. Corona | Note Added: 0034922 |
