0015525 | VTK | (No Category) | public | 2015-06-09 09:32 | 2015-08-07 08:19 | ||||
Reporter | Cory Quammen | ||||||||
Assigned To | T.J. Corona | ||||||||
Product Version | 6.3.0 | ||||||||
Target Version | Fixed in Version | 6.3.0 | |||||||
Summary | 0015525: Crash when point arrays are repeated in VTK unstructured grid XML files | ||||||||
Description | Load the attached file with a vtkXMLUnstructuredGridReader. You should get a crash in vtkAbstractArray::GetNumberOfComponents() because the array instance is NULL. This is because vtkXMLDataReader::ReadPieceData() accesses point data arrays by index, and the maximum index is found by looking at how many point data arrays are defined in the XML file. When a data file has more than one data array with the same name, the XML reader counts all of them. However, vtkPointData can have only one array of a particular name. This leads to the array being requested by index being invalid, hence NULL is returned, hence a crash. The same likely happens for repeat cell arrays. | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
Attached Files | RepeatArrayNameCrash.vtu [^] (1,015 bytes) 2015-06-09 09:32 | ||||||||
(0034912) T.J. Corona (developer) 2015-08-06 18:23 |
Files with multiple point/cell arrays with the same name are now rejected by vtkXMLDataReader. |
(0034918) Cory Quammen (developer) 2015-08-06 22:21 |
Hi T.J., It would be great if you could copy and paste the commit message with the fix here for reference. Thanks, Cory |
(0034921) T.J. Corona (developer) 2015-08-07 08:19 |
Hi Cory, The commit message can be found here: https://gitlab.kitware.com/vtk/vtk/commit/c3a86fd543f7b216c32ef3fccd4d279629e7f462 [^] -T.J. |
2015-06-09 09:32 | Cory Quammen | New Issue | |
2015-06-09 09:32 | Cory Quammen | File Added: RepeatArrayNameCrash.vtu | |
2015-08-05 10:23 | Utkarsh Ayachit | Assigned To | => T.J. Corona |
2015-08-06 18:23 | T.J. Corona | Note Added: 0034912 | |
2015-08-06 18:23 | T.J. Corona | Status | backlog => closed |
2015-08-06 18:23 | T.J. Corona | Resolution | open => fixed |
2015-08-06 18:23 | T.J. Corona | Fixed in Version | => 6.3.0 |
2015-08-06 22:21 | Cory Quammen | Note Added: 0034918 | |
2015-08-07 08:19 | T.J. Corona | Note Added: 0034921 |
