0015488 | ParaView | (No Category) | public | 2015-05-26 05:56 | 2016-08-12 09:59 | ||||
Reporter | Casper van Leeuwen | ||||||||
Priority | normal | Severity | major | Reproducibility | have not tried | ||||
Product Version | 4.3 | ||||||||
Summary | 0015488: Slice representation large dataset only shows half of the data | ||||||||
Description | Hello paraview devs, When I try to visualize a large dataset of ~17gb with the slice representation with 4 processes on two cluster nodes (2x GTX780ti 3gb, 2x Intel Xeon CPU E5-2620 v2, 32gb ram per node) with paraview remote I only see half of the image and paraview gives me the following errors: ERROR: In /sara/sw/build/compiles/ParaView-v4.3.1-source/VTK/Imaging/Core/vtkExtractVOI.cxx, line 212 vtkExtractVOI (0x30aa4b0): Error initializing index map. ERROR: In /sara/sw/build/compiles/ParaView-v4.3.1-source/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 784 vtkCompositeDataPipeline (0x334e200): Algorithm vtkExtractVOI(0x30aa4b0) returned failure for request: vtkInformation (0x3395d80) Debug: Off Modified Time: 1136070 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA FORWARD_DIRECTION: 0 FROM_OUTPUT_PORT: 0 ALGORITHM_AFTER_FORWARD: 1 If you need additional information let me know. Edit: I found out that it renders the slices only from one process (hence the half slice because of 4 chunks of data one for each process), because I also tested it on a greater number of process/nodes and this would result in an even smaller part of the slice visible. I also tested some filters on the data and these seem to be working as intended, so it has nothing to do with the data distribution among the processes. | ||||||||
Steps To Reproduce | The dataset is the woodbranch dataset from this site http://www.ifi.uzh.ch/vmml/research/datasets.html. [^] So the procedure to reproduce is very simple. 1. Start a pvserver on an arbitrary number of nodes above 4. 2. Load the above mention dataset in paraview. 3. Set representation on slice. | ||||||||
Project | TBD | ||||||||
Attached Files | ![]() | ||||||||
(0038825) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-05-26 05:56 | Casper van Leeuwen | New Issue | |
2015-05-26 05:56 | Casper van Leeuwen | File Added: paraviewbug.png | |
2015-05-26 09:04 | Casper van Leeuwen | Description Updated | |
2015-05-26 09:04 | Casper van Leeuwen | Steps to Reproduce Updated | |
2015-05-26 10:31 | Casper van Leeuwen | Severity | minor => major |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038825 | |
