0015378 | ParaView | (No Category) | public | 2015-03-13 12:00 | 2016-08-12 09:59 | ||||
Reporter | john.tourtellott | ||||||||
Product Version | 4.3 | ||||||||
Summary | 0015378: Select cells through frustum doesn't incorporate actor transforms | ||||||||
Description | The paraview feature to select cells via frustum doesn't work right if the actors have a non-identity transform. This is because the vtkExtractSelectedFrustum only works in world coordinates. FYI, I intend to submit a VTK branch to update vtkExtractSelectedFrustum to accept an actor transform as an optional input, which could be used in paraview to make the select-via-frustum feature a bit more general. | ||||||||
Project | TBD | ||||||||
(0038786) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-03-13 12:00 | john.tourtellott | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038786 | |
