0015350 | ParaView | (No Category) | public | 2015-02-27 13:55 | 2015-09-06 12:18 | ||||
Reporter | Burlen | ||||||||
Product Version | git-next | ||||||||
Target Version | Fixed in Version | 4.4 | |||||||
Summary | 0015350: cray atp support | ||||||||
Description | branch: atp-support Integrate Cray ATP Abnormal Termination Processing (ATP) is a system that monitors Cray system user applications. If an application takes a system trap, ATP performs analysis on the dying application. All stack backtraces of the application processes are gathered into a merged stack backtrace tree and written to disk as the file, atpMergedBT.dot. The stack backtrace tree for the first process to die is sent to stderr as is the number of the signal that caused the application to fail. If Linux core dumping is enabled (see ulimit or limit in your shell documentation), a heuristically selected set of processes also dump their cores. To use ATP, the ATP must be linked into the application and the shell environemtn variable ATP_ENABLED=1 must be set prior to launching the program with aprun. This patch adds a CMake module to locate APT libraries and set up link flags. The new module will be used to link ATP lib into the command line executables if the CMake variable PARAVIEW_USE_ATP is ON and ATP is found. Change-Id: I29e817338dd0f199b55d395019d58a6f23f02be4 | ||||||||
Project | TBD | ||||||||
Topic Name | atp-support | ||||||||
Type | feature | ||||||||
(0034281) Burlen (developer) 2015-02-27 13:56 |
on stage should be ok to merge next time |
(0034284) Utkarsh Ayachit (administrator) 2015-03-01 10:47 |
--------------------------------------------- Topics merged into master (v4.3.1-206-g5e2b941): 15193_fix_cell_visibility_array 15333_python_repeatable_values atp-support catalyst-update-20150218 cinema_specA_tweaks_cont pvweb-document-colormap-functionality (VTK) pvweb-local-rendering-all-timesteps |
(0034500) Alan Scott (manager) 2015-06-04 18:44 |
Developer tag in git. Closing. |
2015-02-27 13:55 | Burlen | New Issue | |
2015-02-27 13:55 | Burlen | Assigned To | => Utkarsh Ayachit |
2015-02-27 13:56 | Burlen | Topic Name | => atp-support |
2015-02-27 13:56 | Burlen | Note Added: 0034281 | |
2015-02-27 13:56 | Burlen | Status | backlog => gatekeeper review |
2015-02-27 13:56 | Burlen | Fixed in Version | => git-next |
2015-02-27 13:56 | Burlen | Resolution | open => fixed |
2015-03-01 10:47 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2015-03-01 10:47 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-03-01 10:47 | Utkarsh Ayachit | Note Added: 0034284 | |
2015-06-04 18:44 | Alan Scott | Note Added: 0034500 | |
2015-06-04 18:44 | Alan Scott | Status | customer review => closed |
2015-09-06 12:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
