0015344 | VTK | (No Category) | public | 2015-02-25 00:42 | 2016-03-07 18:06 | ||||
Reporter | David Gobbi | ||||||||
Assigned To | David Gobbi | ||||||||
Product Version | 6.0.0 | ||||||||
Target Version | Fixed in Version | 6.3.0 | |||||||
Summary | 0015344: SetInputData( ) only copies specific hard-coded information to pipeline | ||||||||
Description | The SetInputData( ) method relies on vtkTrivialProducer's FillOutputDataInformation( ) method to copy necessary information from the data object to the pipeline. Unfortunately, FillOutputDataInformation( ) is hard-coded to only copy certain information. For example, it has a hard-coded IsA("vtkImageData") check to see whether it should copy the SPACING and ORIGIN that are needed for vtkImageData. Instead of having a hard-coded IsA( ) check, it should be delegating the task of copying the information to the data object, by calling a the following data object method (which doesn't yet exist): virtual CopyInformationToPipeline(vtkInformation* info); In this way, each data object type can decide for itself what information should be copied. There is already a strong precedent for this, because copying the info in the other direction (from the pipeline to the data object) is done by a virtual method called CopyInformationFromPipeline( ). So CopyInformationToPipeline( ) will provide a very nice symmetry. | ||||||||
Project | TBD | ||||||||
Type | feature | ||||||||
(0034280) David Gobbi (developer) 2015-02-26 08:29 |
http://review.source.kitware.com/#/t/5502/ [^] |
(0035834) David Gobbi (developer) 2016-03-07 18:06 |
Was fixed in VTK 6.3 by commit a8a773be. |
2015-02-25 00:42 | David Gobbi | New Issue | |
2015-02-25 00:42 | David Gobbi | Assigned To | => David Gobbi |
2015-02-25 22:51 | David Gobbi | Status | backlog => active development |
2015-02-26 08:29 | David Gobbi | Note Added: 0034280 | |
2015-02-26 08:29 | David Gobbi | Status | active development => gerrit review |
2016-03-07 18:06 | David Gobbi | Note Added: 0035834 | |
2016-03-07 18:06 | David Gobbi | Status | gerrit review => closed |
2016-03-07 18:06 | David Gobbi | Resolution | open => fixed |
2016-03-07 18:06 | David Gobbi | Fixed in Version | => 6.3.0 |
